Home > Maintenance & Modifications > A pillar grab handle
Page 2 of 3 <123>
Mo Murphy
A point I raised in the last thread about screwing handles to A pillar covers.
50 Shades of Pennine Grey
Post #830673 12th May 2020 12:05pm
Whilst you wouldn't want to swing from them like a gorilla, mine have been fine as a helping hand when the steering wheel isn't fitted. As I mentioned above though, I have used some slightly larger bolts. Darren
Post #830675 12th May 2020 12:08pm
CarMan wrote:
LandRoverAnorak wrote:
I replaced the screws on mine with some M5 pan head bolts, which gripped a lot more solidly.
My understanding is that the fixings are currently screws, so can you kindly explain to an amateur how to replace with bolts Thumbs Up
I imagine LRA actually used setscrews rather than bolts.
If you were to use a threadforming setscrew such as a Taptite it would cut its own thread, but the measure of success would rather depend on how much damage the original self-tappers had done to the bosses within which the holes are located.
Post #830677 12th May 2020 12:09pm
To be more precise, it was a machine screw, just used in a very imprecise way Laughing Darren
Post #830681 12th May 2020 12:19pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Does it do any harm pulling yourself in/up with the steering wheel? I do it most of the time (ducking at the same time). I could do with a grab handle on the cubby box!
Post #830711 12th May 2020 3:50pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
One of the more generously proportioned chaps at work managed to pull the chubby box out of one of the 110s using it as a grab handle to get in and went straight on his backside.
Wasn't funny at all.
Chubby boxes now have very large repair washers in and are bolted through the floor with very large washers to reinforce the other side.....
Post #830732 12th May 2020 5:43pm
Jas Ardis
United Kingdom 2012 Defender 110 Puma 2.2 USW Auto Stornoway Grey
I fitted an aluminium handle to my passenger side A pillar and it was useless. Every time anyone used it, it moved. The screws, and indeed I think the pillar, were simply not designed for this arrangement.
Post #841411 2nd Jul 2020 10:22pm
HardCharger
Is there a way to add a reinforcement to the A-pillar so that this can be a fully functional grab handle?
It's one of the first things people, big and small, look for when first trying to get into the front passenger area. I just tell them to use the "Dear God" handle.
Post #841414 3rd Jul 2020 12:26am
Jas Ardis
@HardCharger, I’m not sure. You’re right that it’s needed, but the handle over the door that I’m sure was there on my last Defender isn’t there (anyway, I have a console fitted that extends to the roof/door interface). My wife is just over 5 foot and she has to use pitons and a base camp to reach the door handle.
I did fit an external loop handle which I will photograph as soon as I’ve had a coffee and regained basic motor skills.....
Post #841425 3rd Jul 2020 6:39am
Doubtful, short of fitting an internal roll hoop I would think.
I have the plastic handles that were on the inside of the front doors now fitted to my A pillars and find them very useful. They are not very strong handles and neither look nor feel very strong, so instinctively you tend to be gentle with them, and this actually helps.
I wouldn't mount a really robust looking or feeling handle there since it would give the false impression of being strong.
Post #841435 3rd Jul 2020 7:38am
Jas Ardis
+1 to that.
Do any passengers reach for the big fat handle under (where you can fit) the glove compartment? I don’t recall seeing that ever happen ...
Post #841451 3rd Jul 2020 8:27am
Jas Ardis
This is the passenger grab loop when not in use ...
Post #841456 3rd Jul 2020 8:58am
Jas Ardis
Post #841457 3rd Jul 2020 8:58am
Jas Ardis
... and this is it ready for use.
Post #841458 3rd Jul 2020 9:00am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The strips that the self tappers go into to hold the trim do not have any strength, they are only designed to hold the trim. When I purchased the 110 second hand the drivers side trim piece was way off the windscreen on removing the trim I saw that the strip was ben outwards, I used gentle thump pressure to push it back into shape. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #841468 3rd Jul 2020 10:11am
Page 2 of 3 <123>
