Home > Maintenance & Modifications > A pillar grab handle
Page 1 of 3 123>
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
After seeing this on LandRoverAnorak thread I thought it's just what I needed so with a set of spare handle I fitted them but I put a 2mm foam gasket between the handle and plastic A post cover as I just could not get them to sit together nice .I have also relocated the power cable and ran it though the steel pipe in front of the cubby box which keeps it well hidden.Also I fitted a 2nd hand alloy steering guard so apart from a good clean she ready to go back on the road next month hopefully.
Post #830321 10th May 2020 4:28pm
grafty99
Nice Thumbs Up
I've put a grab handle on the passenger side of my 90 too, looks like it should have been there from the factory 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #830324 10th May 2020 4:32pm
legin
I was only going to do the drivers side as without the steering wheel fitted there's nothing to grab hold of when getting in but like you say when fitted they look like the handle should be there so fitted passenger side too .
Post #830326 10th May 2020 4:46pm
grafty99
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #830339 10th May 2020 5:38pm
Merlin
What are they fixed to? Peter
Post #830466 11th May 2020 2:08pm
Adammacky
They fit in the existing screw holes already there in the pillars, the screw placement is exactly right, its as if land rover knew... Shocked
Post #830467 11th May 2020 2:11pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
I've been thinking about this mod for the passenger side. If the handles are fixed into the existing A-post screw holes, are they actually any good, you know, for grabbing.
Also, has anyone tried this with the extra deep A-post trims? I was thinking about getting a pair so that my rear washer pipe doesn't get crushed...again.
Thanks
Post #830479 11th May 2020 3:09pm
I replaced the screws on mine with some M4 pan head bolts, which gripped a lot more solidly. Darren
Post #830485 11th May 2020 3:34pm
JoolsB
Thanks, on the list it goes!
Post #830617 12th May 2020 8:52am
CarMan
LandRoverAnorak wrote:
I replaced the screws on mine with some M5 pan head bolts, which gripped a lot more solidly.
My understanding is that the fixings are currently screws, so can you kindly explain to an amateur how to replace with bolts Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #830634 12th May 2020 9:30am
The size isn't far off M4 anyway so I rather brutally forced them in. If I had the correct sized tap then I would have run that through first but the alloy frame is relatively soft and it's worked ok. I've been able to remove and reinsert the bolts without issue. Darren
Post #830644 12th May 2020 9:57am
Bluest
Are they just self-tapped into the metal as standard? 2007 110 TDCi Station Wagon XS
Post #830645 12th May 2020 9:59am
The original screws? Yes, it seems so. Darren
Post #830649 12th May 2020 10:24am
camelman
Are you confident the self tappers will take the wait of a grown bloke pulling themselves into the truck using just the handle? They're only designed to hold a bit of plastic trim in place.
Post #830651 12th May 2020 10:34am
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
This is what I was thinking My confidence has been writing cheques that my abilities can't cash for years.
Post #830668 12th May 2020 11:40am
Page 1 of 3 123>
