Home > Maintenance & Modifications > A pillar grab handle
Page 3 of 3 <123
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
I used some slightly larger screws (took a bit of getting in) along with some washers as I Dremel’d the handle a bit to get it to sit flush
You wouldn’t want to swing from it but it’s ok to use for a hand up.
J
Post #841789 4th Jul 2020 5:25pm
The bodge that I employed to fit these handles has been nagging me so today I did the job properly and tapped proper threads into the alloy mounting holes. They're M4 (not M5 as I originally thought) and it was quite easy to do except for not being able to use the standard 'T' handle for the tap because of the closeness to the windscreen:
I also took the opportunity to add some dense foam to the handles to take up the gap between them and the curved trim pieces:
All back together and they're both neater and more securely fixed:
 Darren
Post #851632 23rd Aug 2020 9:41pm
Yesjus
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Santorini Black
Thinking of doing this mod and would be interested to see how it’s held up? Thanks
Post #971402 17th Nov 2022 1:34am
Adammacky
Mines still going strong Thumbs Up
Post #971405 17th Nov 2022 7:18am
Mine are absolutely fine - I use them all of the time. Darren
Post #971407 17th Nov 2022 7:29am
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
Thank you LRA for your HowTo post and pictures. I'll do exactly the same this weekend and will be able to positively answer to my mom today's question "is it possible to add a handle here?" Thumbs Up
Post #985677 15th Mar 2023 9:28pm
Page 3 of 3 <123
