![]() | Home > Technical > Relay Plug Holders - Repair |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 506 ![]() ![]() ![]() |
3-Way Components can also supply some of the Lucas-Rists relay bases -
https://www.3waycomponents.co.uk/Relay-Hol...ay-Holders Including the bracketed type, that will fit to the screw mountings on the bottom of the TD5 centre fuse box panels YQU104850 (1999MY) and YQU000200 (2002MY) - https://www.3waycomponents.co.uk/Relay-Hol...racket-Kit ![]() They also have an ebay shop - http://www.ebaystores.co.uk/3waycomponents . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
As far as I can remember, there are only two uses of the 70A relay you've got there on a Td5 (it is the correct relay).
One is the glow plugs (C0215 in photo below). This has brown and yellow/black 6.0mm² wires (the large power ones) and smaller brown/orange and green/blue wires for the coil. It should be clipped next to the fuse box as shown. The other (C0508) is for the ABS pump which you may or may not have - probably not as you only mention one. This has brown/white and brown/red 4.0mm² and 3.0mm² wires (the large power ones) and smaller black and white/orange wires for the coil. ![]() Click image to enlarge The socket (YPP10005) isn't available from LR nor can I track it down anywhere else. 3way components don't have the same holder as the original part either but they do have an alternative kit: https://www.3waycomponents.co.uk/Relay-Hol...racket-Kit ![]() ![]() |
I can supply YPP10005 with terminals to suit up to 6mm² cable.
![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 11th May 2020 12:59pm. Edited 2 times in total |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 216 ![]() ![]() |
Thank you Martin.
I've now ordered the relay base from them and the following relay; Automotive Relay 12V 70Amp 4 Pin Normally Open - Genuine Tyco/TE Part It looks like the new holder/socket does not hook only the tabs in the relay box, which is a shame. Hopefully I can get it all back together nicely! It's the first time in over a year the Land Rover has had time off ![]() ![]() |
Thank you for your reply Paul. I didn't see it until I had ordered. I will drop you a message as I may want one as the one I ordered I don't think fits the tabs in the box. Plus I might want some spares. ![]() |
