Home > Technical > Relay Plug Holders - Repair
LANDROVER
Isolation tasks on my TD5....
Several of the relay holders are corroded and one melted!
I'm ordering a crimping tool and wire strippers and need relays and holders.
I have a row of black Durite relays in the fuse box under the dash/gear lever area.
Are these the correct ones?
What holder/plug do I need. I would like the plugs to sit on the metal plate as per original.
Under the drivers seat the yellow relays are corroded and keep giving me grief.
What is the correct part no. for these
What holder is required?
There is a black one which has been repaired looks the same as the 30amp Durite one is this correct?
Part Numbers or a suggestion of a supplier would be much appreciated.
Cheers for your help guys, I'm isolating on my own without tools or spares but need to try and make some use of this time. Thumbs Up
Post #824936 13th Apr 2020 10:00am
htb2
Wales
PM Martin on here, he will have the info.
Post #824943 13th Apr 2020 10:14am
dorsetsmith
Post #824946 13th Apr 2020 10:30am
Martin
Site Admin
Durite aren't original, they are an aftermarket supplier, but there is nothing "wrong" with them as components.
Best bet if you can is to photo what you have and what you need to replace.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #824951 13th Apr 2020 11:14am
dorsetsmith
JRL use Tyco (now TE Connectivity)
The Yellow sockets are P/N AFU3271
The Black sockets are P/N YPP10005
The brown sockets are p/N YPP10004
Post #824958 13th Apr 2020 12:01pm
LANDROVER
Thank you for all your replies.
I think I have ordered all the right bits!
I will try and upload a picture at some point....its a mess of bodges which I'm trying to sort.
One relay actually melted and burnt the carpet!
I have ordered;
Genuine Lucas Yellow Relay Holders
Durite 0-727-15 for relay box (Wipers, Heated Windscreen etc)
Ford Yellow V23136-B1-X33 for underseat (fuel pump etc)
I see you can buy Black replacement relays from Bearmach. Seem quite a reasonable price but not sure if they are reliable enough?
I know when my yellow relay played up before it was creating all sorts of havoc so trying to eliminate any issues whilst I finally have some down time.
Hopefully these items arrive.
Thanks again everyone, stay safe.
Thumbs Up
Post #824976 13th Apr 2020 1:01pm
rallysteve
Lucas Rists relay holders are what i generally use, they fit onto all of the mounting tabs under the fusebox and seatbox. I always use Tyco/TE relays though
Post #824979 13th Apr 2020 1:10pm
LANDROVER
This is what I'm dealing with. Removed some of the worst! The battery bay is just dangerous at the moment.
Post #824980 13th Apr 2020 1:10pm
Martin
Site Admin
*shudder*
Someone's had a good go at the underseat wiring in the past Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #824983 13th Apr 2020 1:31pm
dorsetsmith
The only think to Add part number is holders only no connectors
Post #824984 13th Apr 2020 1:42pm
LANDROVER
Martin wrote:
*shudder*
They certainly have!
Slowly getting it sorted....it's amazing the things you always find when you buy something used. Especially Land Rover...people like to tinker Laughing
Got to secure the ECU wiring loom. Its been raised but the harness has just been crammed through the cover. Its chaffed through the insulation luckily only the Black braided part.
Do people run them inside the door pillar normally?
I can't find a decent picture of how it's routed nicely.
Under the Passenger seat the batteries are not secured and the solenoid for the dual batteries is lay loose Rolling Eyes
Because I use it everyday I've just had to make do but now is the perfect time to sort it......well maybe a warmer day than today Whistle
Post #824986 13th Apr 2020 2:01pm
LANDROVER
Excellent information. Thank you kindly for your help. Thumbs Up
Post #824987 13th Apr 2020 2:02pm
PaulMc
I have the 70A 4-way relay bases YPP10005 and terminals to suit up to 6.0mm² cable.
I also have the 5-way yellow AFU3271 bases, as well as the green, black, and ‘natural’ versions (no brown, unfortunately), with terminals to suit various cable sizes.
I also have a small quantity of the 9-way relay bases AFU4177 used for wiper delay, dim-dip, and heated screen timer relays
PM me if interested Thumbs Up Paul.
Post #824991 13th Apr 2020 2:36pm
PaulMc
Depending on the model year, they have either been Lucas-Rists, TE Connectivity, or Lear (marked with BMW part numbers), or a mix of types. Paul.
Post #824994 13th Apr 2020 2:43pm
dorsetsmith
just other suppler i going Recommend ^ Thumbs Up
Post #824995 13th Apr 2020 2:50pm
