Home > Technical > Coolant change - 2.2 Defender (2014) without fuel cooler
Rutter
United Kingdom 2014 Defender 90 Puma 2.2 SW Rioja Red
Hi Guys,
Looking for help - I have embarked on a coolant change using both Haynes manual and my (2012) workshop manual. Both say to remove the coolant hoses from the fuel cooler. Problem is that since 2014 there is no fuel cooler..!
Is it best to unclip the lowest hose to the rad in order to drain coolant..?
Post #830274 10th May 2020 1:51pm
If itโ€™s anything like the 2.4 like mine I used the thermostat hose. I donโ€™t know hardly anything about the2.2 but this is what I did with mine. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #830277 10th May 2020 2:12pm
Rutter
Thanks Steve - thermostat looks to be quite high up on my engine. Pity they didn't fit a rad drain tap...
Post #830279 10th May 2020 2:17pm
Rutter
OK, got it sorted. The sump/steering guard had to come off then you can access the bottom hose coming out of the radiator. Squeeze clips are awful, replaced with proper Jubilee clips to make it easier next time...!
Post #830344 10th May 2020 6:01pm
Good job, at least you got it done. Thumbs Up No Guts, No Glory.
Post #830350 10th May 2020 6:28pm
Rutter
On to easier jobs now, fuel filter and brake/clutch fluid change...
Post #830352 10th May 2020 6:35pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Is it possible to vacuum out the old coolant out of the bleed port?
I canโ€™t see the radiator bottom hose clips without removing the radiator lower shroud.
Post #938831 22nd Jan 2022 1:48pm
