Home > Technical > Coolant change - 2.2 Defender (2014) without fuel cooler |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20578 |
If itโs anything like the 2.4 like mine I used the thermostat hose. I donโt know hardly anything about the2.2 but this is what I did with mine. KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
10th May 2020 2:12pm |
Rutter Member Since: 10 May 2020 Location: Appleby Posts: 5 |
Thanks Steve - thermostat looks to be quite high up on my engine. Pity they didn't fit a rad drain tap...
10th May 2020 2:17pm |
OK, got it sorted. The sump/steering guard had to come off then you can access the bottom hose coming out of the radiator. Squeeze clips are awful, replaced with proper Jubilee clips to make it easier next time...!
10th May 2020 6:01pm |
Good job, at least you got it done. KEEP CALM AND Drill ON
10th May 2020 6:28pm |
On to easier jobs now, fuel filter and brake/clutch fluid change...
10th May 2020 6:35pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 300 |
Is it possible to vacuum out the old coolant out of the bleed port?
I canโt see the radiator bottom hose clips without removing the radiator lower shroud. |
22nd Jan 2022 1:48pm |
