![]() | Home > Maintenance & Modifications > Optimill hinges turned purple? |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
I know it’s a risk with anodised parts, but it sounds like you’ve been pretty careful with them. Could it be UV having an effect? 2014 Keswick Utility 2.2
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Yep... UV damage... Will get worse over time... (every anodized unit does)... Cure is to either re-do the anodizing or paint... It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
I would paint, this is one of the reasons why I avoid anodising like the plague. However careful you are with it.
Years ago I had a bike that had a red headstock too cap that was red anodised. Looked great at first. Then it went cherry red over time then over to a pinky red then a white very light grey red. All UV damage and wasn’t really exposed much to that even. Heat can cause discolouration too but that wouldn’t be it in this case. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Mine are also similar (from what i remember) And i use Gtechniq religiously due to the other car having the crystal serum ultra... I did have some issues with the optimil door handles a while back incorrect bushings fitted, sent them in to be replaced when i didn't need the car for a few weeks and they actually re coated the handles too due to something with the coating |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Very interested in this, as I also have Optimill hinges.Only recently fitted the, so still looking fresh.
Bear100, how old are your hinges? When did you buy them and when were they fitted? Does the car stand outside (like most Defenders)? The bushings look different to mine. They appear to have an aluminium shrouds (visible on your picture) around them. Mine appear to have simply a nylon bushing. The hinges work extremely well, in comparison to the factory hinges, which were a mixture of partially seized (passenger door) and partially worn to the point of having lots of play (drivers door). ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTs, Recaro CSs, anorak, wellingtons |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 189 ![]() ![]() ![]() |
Mine have been on for 2 years and look brand new, don't know if it makes a difference but I use Optiwash regularly
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2533 ![]() ![]() ![]() |
Anodic coatings are all susceptible to the effects of ultra violet light and chemicals. Some anodic dye colours are less resistant than others so that is maybe why some forum members have reported little or no discolouration.
For black anodising to discolour so quickly (only after two years) I would be querying the anodising process used by Optimil's suppliers. I would also query the specification given to their anodisers, as has been stated above most Defenders are kept outside and therefore exposed to UV and chemicals are used in the wash process. It would be interesting to check if they are having their components anodised to BS EN ISO 7599:2010. Custom 90 Steve seems to have the answer - Paint them Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1953 ![]() ![]() ![]() |
Mine are only 10 months old, they cost a small fortune and hopped they would be a fit and forget
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Speak to James at Optimil I think they have had a few sets that have turned purple so maybe a bad batch from anodiser? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
Surprised that nobody offers Xylan or Halar (both fluoropolymers) as a coating option, yes they may only be available in duller or dark colours, but much more resistant to acid and alkalis, hydrophobic and a higher UV resistance. Yes there are some downsides, but in my opinion much better than anodizing. Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Installed mine in January 2020. 4 months later it’s turns purple. The door handle and rear door hinges are perfectly fine. According to optimill it’s my fault. Anyone painted their optimill? Any pics?
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
If after four months they have turned purple then under the sale of goods act they are not fit for purpose. Demand a refund or replacement. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 ![]() ![]() |
Mine have been on for well over 2 years now and are still like new. Vehicle is outside and in full sun too.
It seems might be the anodising process might have a problem. But company point of view or support seems defensive and point at customer fault. Like many people here, had spent a good amount of money with the company. If they would have simply admit might be their fault, and willing to help, personally I could have bought more of their products. I was in the mid of upgrading all my interior furniture. But at the end gone to another company instead. So either looking to repaint those hinges or flog it and get another company hinges.
