Home > Tdi > What is the purpose of this hose? |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 623 |
It is off the EGR system. I expect yours has been removed. All the ones I have removed I have pulled the redundant elbow out of the rubber intake hose and bunged up the small hole with some black Sikaflex / Carbond.
With the brake servo hose I used to order the genuine straight hose from the non EGR 300tdi 90 and fit that instead of the one you have with the Tee off. You can blank it with a small screw but it looks bodged, the genuine hose used to only be a couple of pounds. |
26th Apr 2020 6:53pm |
KiwiNCFC Member Since: 14 Jul 2019 Location: East anglia Posts: 46 |
Thanks for your help! Very informative. Yes I removed the egr about 18 months ago but at the time I blanked the egr vaccumn hose off with a bung. The hose in the picture actually has broken off the valve modulator which is what I found. Found the part number for that non egr hose ANR2783 if anyone is searching in years to come!
What does the line to the brake servo actually provide though? |
26th Apr 2020 8:22pm |
roliver Member Since: 24 Nov 2016 Location: Cambridge Posts: 60 |
I've been looking at replacing my hose with the ANR2783 part but they're crazy expensive.... like £80/£90 expensive.
29th Apr 2020 5:37pm |
