Home > Puma (Tdci) > Stereo upgrade
Page 1 of 4 1234>
Markh
England 2010 Defender 110 Puma 2.4 XS CSW Java Black
Stereo upgrade
I've finally got round to upgrading my speaker system!
replaced the head unit a while ago but now added my sub woofer
plus replaced the rear speakers with some decent ones
Just need to get some carpet to cover the MDF to finish the job ...
makes a massive difference to the sound! "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #82636 30th Jul 2011 9:44am
K9F
Nice job!
A few other stereo upgrade threads that may interest....lots more too!!!! Thumbs Up
http://www.defender2.net/forum/topic6140.html?highlight=stereo
http://www.defender2.net/forum/topic7481.html?highlight=stereo
http://www.defender2.net/forum/topic6967.html?highlight=stereo
http://www.defender2.net/forum/topic6471.html?highlight=stereo
http://www.defender2.net/forum/topic6140.html?highlight=stereo If you go through life with your head in the sand....all people will see is an ar5e!!
Post #82642 30th Jul 2011 10:05am
Zagato
Nice job Thumbs Up
Defendoor sell larger speaker housings as well! http://www.defendoor.co.uk/Defender-rear-speakers.php
Yours are much cheaper to do Wink
Post #82661 30th Jul 2011 1:39pm
MK
very nice! do you get already good bass from those in the back? Puma 110" SW
Post #82665 30th Jul 2011 2:28pm
Markh
Rear speakers are a great improvement over the original pair. I ran with them for a couple of weeks before I fitted the sub but it's the sub that really makes the difference. Highly recommend fitting one if you like your music ... "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #82674 30th Jul 2011 4:18pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #82675 30th Jul 2011 4:47pm
dgardel
Italy
Zagato wrote:
Nice job Thumbs Up
Not fit the Puma for the shape of the wings Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #82676 30th Jul 2011 4:49pm
Zagato
No good then Sad Thumbs Up
Post #82678 30th Jul 2011 5:35pm
Markh
Making new mounts out of MDF was easy, created a cardboard template, jig saw and some glue and all done. Once I get the carpet on it hopefully will look like it's ment to be there "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #82682 30th Jul 2011 6:01pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
that's exactly how i fitted my Alpine sub, works a treat. BM52
Post #82683 30th Jul 2011 6:11pm
K9F
I had upgraded my speakers (not the twweters) some considerable time ago which improved the sound of a standard head-unit. I still kept to 10cm speakers as I didn't want to cut the existing orifices on what was a relatively new vehicle. Fitting an upgrade head-unit and an Alpine slimline amp improved the sound quality no end, however at higher volumes the speakers could not handle it. By fitting a subwoofer the lower frequencies from 40-400Hz (normally) are then processed by the subwoofer amp thereby taking the strain away from the remaining speakers. I was sceptical how good a subwoofer may be, the sound now is abolutely brilliant. Anyone considering installing a subwoofer would undoubtedly not be disappointed with the results in my view!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #82686 30th Jul 2011 6:23pm
Def-00
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Fuji White
What brand subwoofer are you using? Markh and dgardel look like you have the same unit. I bought a clarion but might need to replace it as it takes too much space.
 2012 Fuji White 110 Flattened
Post #82713 30th Jul 2011 11:28pm
Markh
Mines the Alpine SWE 1000, comes with everything you need, bracket even allows easy securing to the cubby box. All the cabling sat under the box out the way "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #82722 31st Jul 2011 8:21am
bm52
just as Mark says - an easy fix. just been in and out of London this morning and enjoyed music all the way.
my only issue with the Alpine is probably my ignorance but i find that you have to tune the sub for some tracks but i assume that could be due to the quality of the original recording into an mp3 format? Neutral i have the sub remote tucked down betwwen the seat and cubby box so i easily twiddle the knobs as needed Confused BM52
Post #82740 31st Jul 2011 11:09am
Markh
Have my remote in the same place, have a JVC headunit connects to my iPhone via Bluetooth for the music, I agree can depend on the track for quality, some of the bit rates vary. "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #82751 31st Jul 2011 12:26pm
Page 1 of 4 1234>
