Home > Td5 > TD5 Lights not working |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Bypass the pink dim dip relay would be the best option, or at least a test. The relay has two bigger terminals, those are the two that need to be joined. So even just a short length of wire, with two male spade connectors crimped onto the ends will do.
Obviously that is removing the relay, and using wire bypass into the terminal/relay block. |
14th Apr 2020 11:41am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
An alternative to bypassing the relay is to reach under the O/S front wing and simply unplug the connector from the dim-dip resistor. (This is the location on a 2.4 TDCi, but I think the TD5 is in the same place).
14th Apr 2020 11:59am |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Cheers Andy will try that.
Yes. Same place on TD5. Sort of below the fm aerial. |
14th Apr 2020 1:43pm |
Still not sure why the fog light button has anything to do with it though?
14th Apr 2020 2:06pm |
Because the operation of the fog light is linked to the headlights being on.
To be honest, I wonder if the buzzing dim/dip relay is a symptom of a failing light switch rather than the cause of the problem? It won't do any harm to disconnect it as described above but this bit from your first post: "I have side lights and full beam with the stalk pulled back to flash but no dipped beam", is classic melted switch contacts. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Apr 2020 3:04pm |
The switch was replaced when I added the Boomslang loom so wouldn't have thought it was the switch?
Thanks though |
14th Apr 2020 3:15pm |
Le Land Rover elettriche sono peggiori di quelle italiane se la insulti in questo modo non farà che peggiorare |
14th Apr 2020 3:49pm |
Adora che le parli sporco
14th Apr 2020 3:59pm |
Working side and flash but neither constant dip nor main headlights is usually symptomatic of the main light switch having failed, but the odd thing with the OP's problem is that he has LED lights and still has dim dip, since LEDs usually don't work with dim dip.
Personally, the first thing I would do is disable the dim dip, and then - assuming that the fault is still present which is likely - investigate the switches. The fact that the switch is recent doesn't mean that it isn't faulty, and also there are two switches involved (the side/head on/off switch and the dip/main switch). The noise from the relay suggests to me that it is getting a significantly reduced voltage which is insufficient to energise it reliably. |
14th Apr 2020 4:48pm |
Thanks for all the advice.
So, after a lot of methodical checks, which is unusual for me!, I found the problem. Turned out to be the headlight relay next to the fuse box. The yellow one. Not sure if it wasnt seated correctly or corroded. Anyway, took it out and cleaned it up and the problem was solved. Thanks again, thats what this forum is good for, excellent help and advice. |
16th Apr 2020 12:15pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 943 |
Its great that you posted your fix. That way everyone can learn 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Apr 2020 5:51pm |
