Home > Td5 > TD5 Lights not working
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Sorry everyone, I know this is a common thread but he goes anyway.
I have a 2004 TD5 with a boomslang loom and TruckLite lights.Generally these work ok however I intermittently have a problem when they dont work. This tends to manifest itself with the pink dim dip relay buzzing for a bit but then they come back on and all is good for ages.
Anyway, I had the dash off to change the lights in the dials to LED from Classic Car LED Ltd classiccarleds.co.uk great service and great pieces of kit at a really good price. LED's work a treat and really pleased. Anyway, I digress. While putting the dash back in I have no lights! I have side lights and full beam with the stalk pulled back to flash but no dipped beam. The dim dipped relay sometimes buzzes but not all the time. When it does, and I push the fog light switch, the dim dip relay stops buzzing! I think I may have an earth issue? Is the big green block behind the dash an earth block. What else could be the problem?
Land Rover electric are worse than Italian electics Rolling with laughter
Post #825166 14th Apr 2020 10:51am
landy andy
Bypass the pink dim dip relay would be the best option, or at least a test. The relay has two bigger terminals, those are the two that need to be joined. So even just a short length of wire, with two male spade connectors crimped onto the ends will do.
Obviously that is removing the relay, and using wire bypass into the terminal/relay block.
Post #825183 14th Apr 2020 11:41am
An alternative to bypassing the relay is to reach under the O/S front wing and simply unplug the connector from the dim-dip resistor. (This is the location on a 2.4 TDCi, but I think the TD5 is in the same place).
Post #825195 14th Apr 2020 11:59am
Tank
Cheers Andy will try that.
Post #825196 14th Apr 2020 11:59am
landy andy
Yes. Same place on TD5. Sort of below the fm aerial.
Post #825222 14th Apr 2020 1:43pm
Tank
Still not sure why the fog light button has anything to do with it though?
Post #825225 14th Apr 2020 2:06pm
Because the operation of the fog light is linked to the headlights being on.
To be honest, I wonder if the buzzing dim/dip relay is a symptom of a failing light switch rather than the cause of the problem? It won't do any harm to disconnect it as described above but this bit from your first post: "I have side lights and full beam with the stalk pulled back to flash but no dipped beam", is classic melted switch contacts. Darren
Post #825240 14th Apr 2020 3:04pm
Tank
The switch was replaced when I added the Boomslang loom so wouldn't have thought it was the switch?
Thanks though
Post #825241 14th Apr 2020 3:15pm
dorsetsmith
Re: TD5 Lights not working
Le Land Rover elettriche sono peggiori di quelle italiane se la insulti in questo modo non farà che peggiorare
Post #825248 14th Apr 2020 3:49pm
Tank
Adora che le parli sporco
Post #825251 14th Apr 2020 3:59pm
Working side and flash but neither constant dip nor main headlights is usually symptomatic of the main light switch having failed, but the odd thing with the OP's problem is that he has LED lights and still has dim dip, since LEDs usually don't work with dim dip.
Personally, the first thing I would do is disable the dim dip, and then - assuming that the fault is still present which is likely - investigate the switches.
The fact that the switch is recent doesn't mean that it isn't faulty, and also there are two switches involved (the side/head on/off switch and the dip/main switch).
The noise from the relay suggests to me that it is getting a significantly reduced voltage which is insufficient to energise it reliably.
Post #825268 14th Apr 2020 4:48pm
Tank
Thanks for all the advice.
So, after a lot of methodical checks, which is unusual for me!, I found the problem. Turned out to be the headlight relay next to the fuse box. The yellow one. Not sure if it wasnt seated correctly or corroded. Anyway, took it out and cleaned it up and the problem was solved.
Thanks again, thats what this forum is good for, excellent help and advice.
Thumbs Up
Post #825794 16th Apr 2020 12:15pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Its great that you posted your fix. That way everyone can learn Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #825849 16th Apr 2020 5:51pm
