Home > My Defender > What Did You Do In Your Defender Today |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Haha, trusty D1 200tdi |
8th Apr 2020 7:30pm |
NickMSM Member Since: 18 Aug 2016 Location: W Sussex Posts: 109 |
Fitted some x-trouser door strikers today as my nearside striker was worn.
8th Apr 2020 9:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
AJC - Canโt go wrong with First Four.
Peter has always been most helpful. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
8th Apr 2020 9:43pm |
Their products always look well made.
9th Apr 2020 5:22am |
notxal Member Since: 20 Nov 2019 Location: Shropshire Posts: 89 |
A job that has been put off for a long time was refurbishing the 3 steps. Today I finally worked up the motivation and got them off, removed the plastic and rubber covers, de-rusted them and applied a coat of POR 15.
Click image to enlarge |
9th Apr 2020 4:16pm |
Wow ~ hard to tell they're not brand new.
9th Apr 2020 4:20pm |
Very good job done there. ๐๐ป KEEP CALM AND Drill ON
9th Apr 2020 5:15pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Came to use the 110 for the first time in about a week and nope. Not starting. Just clicks from the starter.
Voltage 11.5v. Now on charge. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
10th Apr 2020 12:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17520 |
Both my Def and my Disco have been on CTEKs since the start of the solitary confinement. It's amazing how well they start for the weekly foraging run when they are on constant charge!
10th Apr 2020 1:23pm |
I noted how good the 110 started last time the battery went flat. I suppose i am probably looking at a new battery at some point. But for now its on charge over night. [/list] 1999 Defender TD5 110
10th Apr 2020 2:39pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 919 |
Click image to enlarge Went to county hall to collect PPE for the local Dr's surgery. Was also nice to have a longer trip to keep everything happy. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
10th Apr 2020 2:51pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
Liking that pic Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
10th Apr 2020 8:30pm |
While looking for some wiring under the drivers seat, found the base of the seat box with a nice layer of oil. Red ECU plug having an oil party!
Cleaned out as much oil as I could with electrical contact cleaner. New under rocker cover loom required - email to Duckworths The last time I changed the loom was about 6 years ago. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th Apr 2020 1:06pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
I mounted the battery cut off switch next to the winch switch. For the job I used 50mm2 cable and 300A(1000A max) switch.
And most important... I found out how to fully open my Sheelman seats! Click image to enlarge Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
12th Apr 2020 5:28pm |
