Home > My Defender > a 130 itch |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Love a 130! James
6th Apr 2020 2:34pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10835 |
Cracking on there with the work and looking good jst Clayton.
6th Apr 2020 7:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8139 |
oops, bought a webasto cab heater, well it's going to be a big space to heat when rear is all enclosed! now that wasn't on the list. a little ebay find seemed a shame not to take the opportunity!
Ashcrofts are just putting together a nice rear diff for me. hypoid low pinion. same as my 110. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Apr 2020 6:41am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1231 |
They look like Zu's. If you want better lock then I can recommend them. Fitted a set of them to my 110 and will out-turn a standard 90 now, that's on 265/75R16s rather than 235s. If you want worse lock then go for a Sandringham! Click image to enlarge Have you not thought about leaving it as a tray-back / pick-up and having a demountable camper on the back? I'm planning on building something like that for the 6x6, a bit like what Leigh & Steph have with GrizzlyNBear - has the benefit you can set up camp and go off exploring without having to lug the camper around. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
7th Apr 2020 7:18am |
That would look cool on the 6x6 sako Clayton.
7th Apr 2020 7:14pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Chaps with 130s make sure your wheels are up to specific vehicle weight
Some of the wheels I see don’t fit the bill |
7th Apr 2020 8:04pm |
i did think of the demountable option. reality is i need a closed in back for 90% of what i do so dont want to run it as a pick up anyway. still working through rear cab options.
still waiting on filter housing today so finished calipers off in the hour i had in the wksp. Llama4x4 hoses arrived now as has Craddocks order so can do the rear discs/wheel bearings and get the replacement calipers on, will also change the rear flexi for a braided one. these will be going on the front, chassis direct to caliper so you have one less join and can take caliper off easily. Click image to enlarge Gwyns new poly TRE covers, meant to last longer than the std rubber ones which last two mins if they contacts anything off road! Gwyns drag, track rods and steering guard to go on, probably after the front locker has gone in to save guard coming on/off/on Click image to enlarge Have some crud guards to fit as well! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Apr 2020 8:16pm |
7th Apr 2020 8:17pm |
There are two jobs i dont rush to do. One is taking a drop arm off the steering box the other is waxoyling!
Weather was good so today was the planned day for the waxoyl, outside to reduce mess and cleaning up! Slight issue, broken fuel filter housing so a faff to tow it out. Part was due yesterday, message from retailer this am to say should be with me tomorrow! Tow rope it was then, got my 11 year old to tow me out! Turned out to be ok waxoyling in the end, ran it through a compressor spray gun after warming waxoyl to ease flow. Click image to enlarge Click image to enlarge It went so well in fact I then cracked on and fitted the front mud shields Click image to enlarge Then filter housing turned up! Fitted tank end pipes first, after refilling filter, then connected front pipes, thankfully she fired up and ran a dream, no fuel bleed required! Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Apr 2020 6:07pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
Nice work James
8th Apr 2020 6:19pm |
spare wheel carrier turned up today!
thanks Jamie, its coming along. Just pondering doing rear brakes or waiting to do the whole lot in one go. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Apr 2020 8:34pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1631 |
drive it a bit before the brakes get done
8th Apr 2020 8:40pm |
would do if i could turn it out of my driveway..... need some zero ET rims! ZUs or wolfs!?
both discs are lipped and caliper pistons not going back in so although she stops really well currently, they will need doing so time to do i think - whilst i seem to have this spare time! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
9th Apr 2020 11:33am |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1874 |
I've got as set of Zu's (ET11 iirc) and new 255/85's that'll be for sale when all this is over Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
9th Apr 2020 11:59am |
