Home > My Defender > New chassis 300 tdi 90
Page 2 of 2 <12
Pilgrimmick
Been sat for nearly two years, so looks much worse than it was.
Gets washed every year for the MOT whether it needs it or not!
The doors are being replaced, before you day anything! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #821594 27th Mar 2020 10:50am
Pilgrimmick
Work so far.
 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #822381 30th Mar 2020 9:12pm
ibexman
Where’s the rear tank from mick
Post #822428 31st Mar 2020 12:03am
Pilgrimmick
It was a tank made by Foleys when I had the first galvanised chassis fitted, gives a nice extra range, but think a td5 tank may have been a better option, it can be very difficult to fill, it only tops up the main tank, not plumbed in for fuel return etc, so not as versatile as a true second tank. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #822454 31st Mar 2020 9:30am
Procta
Near to where I live, some Censored would try and hot wire the defender body Laughing Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #822542 31st Mar 2020 7:18pm
Mdm
to be fair they have not hung around with it but not ideal to drop it on the floor like that...
chassis doesnt look to bad considering you only wash it once a year and the foley tank looks like its lasted well
how many ltrs is it and does it fit to std mounting points as that will be useful to some one if your going back to std set up this time.
plenty of wax inside the doors this time round as well
are you having the axles balsted and painted or just a quick swap over to the new chassis?
Post #822592 31st Mar 2020 9:13pm
Pilgrimmick
The chassis is completely shot underneath, too dangerous to drive!
The tank should last well it cost enough, made of stainless, about 45 litres, so not as big as it could have been, think it was just the simplest tank they could make, it is all going back, the tank, discountable hydraulic winch system, split charge, the lot.
The axles are being blasted, new seals and painted.
The side doors are in my workshop, primed, three layers and painted, three layers, new seals and locks. Military style two piece.
The rear door is being replaced by Tayside Land Rover. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #822597 31st Mar 2020 9:24pm
htb2
Wales
Where is the hydraulic pump for the winches as I cannot see a pump in the normal place on the PTO output on the transfer box
Post #822605 31st Mar 2020 9:41pm
Mdm
cool what paint are you doing the axles in?
tank looks good to be fair i had one made a while back for my 90 and it wasn't as good as that and in the end i took it off as it was to a tad low for off road use.
are you doing anything to the engine or running gear while sits on the floor clutch etc?
Post #822606 31st Mar 2020 9:42pm
Pilgrimmick
The winch has an engine mounted pump, will replace it with a transfer box mounted pump when I get the car back.
The tank sits nicely out of the way, I also have a tank guard that follows the chassis profile if doing serious off road work. I am having the seals replaced on the crank, I think the clutch is good, but will see what it looks like once it comes out.
Everything is on a budget, so somethings will be left till later, but the majority of work will be done during the swap. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #822614 31st Mar 2020 9:57pm
htb2
Wales
Ah see the pulley now for the pump above the fan pulley, where aircon would have been.
Post #822671 1st Apr 2020 9:35am
Pilgrimmick
Progress so far. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #829941 8th May 2020 7:01pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Pilgrimmick wrote:
I live about twelve miles from the coast, it has never been into the sea. Still undecided about additional coatings for the chassis. Like everything, cost is a factor!
I used Jotun hardtop flexi a marine 2pac paint on my chassis, I know I haven’t done any mileage with her yet but the coating seems excellent so far and wasn’t that expensive Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #829960 8th May 2020 8:19pm
frenchy
look great when getting put back together.
I had my chassis replaced two years ago on my 300 tdi.
2 coats of Buzzweld 'galv in one' on the Richards chassis before refitting
 2000 D2 TD5 - ahhh bless
2006 D3 - no longer with us and sadly missed
1997 300tdi d90 - now with electrics that work!
- now with a brand new custom made soft top fitted
…...…...............….new chassis now all fixed and driving like new
2010 D4 alas no more, but a lovely colour (Nara)
2016 D4 battery magically fixed with NOCO charger
Post #830353 10th May 2020 7:40pm
Page 2 of 2 <12
