Home > My Defender > New chassis 300 tdi 90 |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
Work so far.
Click image to enlarge 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
30th Mar 2020 8:12pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Where’s the rear tank from mick
30th Mar 2020 11:03pm |
It was a tank made by Foleys when I had the first galvanised chassis fitted, gives a nice extra range, but think a td5 tank may have been a better option, it can be very difficult to fill, it only tops up the main tank, not plumbed in for fuel return etc, so not as versatile as a true second tank. 80" 1948
31st Mar 2020 8:30am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
Near to where I live, some would try and hot wire the defender body Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
31st Mar 2020 6:18pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1600 |
to be fair they have not hung around with it but not ideal to drop it on the floor like that...
chassis doesnt look to bad considering you only wash it once a year and the foley tank looks like its lasted well how many ltrs is it and does it fit to std mounting points as that will be useful to some one if your going back to std set up this time. plenty of wax inside the doors this time round as well are you having the axles balsted and painted or just a quick swap over to the new chassis? |
31st Mar 2020 8:13pm |
The chassis is completely shot underneath, too dangerous to drive!
The tank should last well it cost enough, made of stainless, about 45 litres, so not as big as it could have been, think it was just the simplest tank they could make, it is all going back, the tank, discountable hydraulic winch system, split charge, the lot. The axles are being blasted, new seals and painted. The side doors are in my workshop, primed, three layers and painted, three layers, new seals and locks. Military style two piece. The rear door is being replaced by Tayside Land Rover. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
31st Mar 2020 8:24pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Where is the hydraulic pump for the winches as I cannot see a pump in the normal place on the PTO output on the transfer box
31st Mar 2020 8:41pm |
cool what paint are you doing the axles in?
tank looks good to be fair i had one made a while back for my 90 and it wasn't as good as that and in the end i took it off as it was to a tad low for off road use. are you doing anything to the engine or running gear while sits on the floor clutch etc? |
31st Mar 2020 8:42pm |
The winch has an engine mounted pump, will replace it with a transfer box mounted pump when I get the car back.
The tank sits nicely out of the way, I also have a tank guard that follows the chassis profile if doing serious off road work. I am having the seals replaced on the crank, I think the clutch is good, but will see what it looks like once it comes out. Everything is on a budget, so somethings will be left till later, but the majority of work will be done during the swap. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
31st Mar 2020 8:57pm |
Ah see the pulley now for the pump above the fan pulley, where aircon would have been.
1st Apr 2020 8:35am |
Click image to enlarge Click image to enlarge Click image to enlarge Progress so far. 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
8th May 2020 6:01pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I used Jotun hardtop flexi a marine 2pac paint on my chassis, I know I haven’t done any mileage with her yet but the coating seems excellent so far and wasn’t that expensive 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
8th May 2020 7:19pm |
frenchy Member Since: 05 Feb 2012 Location: Liverpool Posts: 133 |
look great when getting put back together.
I had my chassis replaced two years ago on my 300 tdi. 2 coats of Buzzweld 'galv in one' on the Richards chassis before refitting Click image to enlarge Click image to enlarge Click image to enlarge 2000 D2 TD5 - ahhh bless 2006 D3 - no longer with us and sadly missed 1997 300tdi d90 - now with electrics that work! - now with a brand new custom made soft top fitted …...…...............….new chassis now all fixed and driving like new 2010 D4 alas no more, but a lovely colour (Nara) 2016 D4 battery magically fixed with NOCO charger |
10th May 2020 6:40pm |
