Home > Maintenance & Modifications > Carpet Trim Question
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Chaps, the carpet in my XS - particulary around the seat bases and the carpet mats, is fixed in place by what looks like a black domed pushpins with an orange sleeve on the back. You can see the orange thingy by looking underneath at the chassis or peering into the seatbox. Question - how do you get these pins out, so you can remove the carpet trim ????
Does this orange thingy come off?? Do they screw in?? Have a head cover?? Had a good fiddle earlier and they are well in! Are they reusable or one time only ??
Post #80682 17th Jul 2011 5:10pm
bob neville
Martyn
They are reusable if you remove the black pin with care.
I use a trim removing tool on the black pins, it pushes down on the plug and stops it getting damaged.
Bob
Post #80872 18th Jul 2011 7:25pm
lrMike
Greece
Martyn,
Unfortunately I did the job first and then asked questions Smile That means I damaged the plastic cups when I removed the black pins. A nice tip from a fellow here is to put some vaselin or grease inside the cup in order to be easier to pull off the pins if needed in the future.
Mike
Post #81391 21st Jul 2011 11:44am
you can get replacements from LR and halfords (in the UK)
Post #81464 21st Jul 2011 8:03pm
110SEB
I've chosen to lose the carpets under the mats. They sponge up moisture and pi55 me off. Much less hassle with just the LR rubber underfoot.
Post #81466 21st Jul 2011 8:07pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i second that, no carpets since my first time off road, we did get more than a couple of inches of water in the cab Embarassed
1200 miles on the clock and people thought i was daft.
Post #81617 22nd Jul 2011 10:10pm
Martyn
lrMike wrote:
Martyn,
Mike
Thanks for that Mike. I take it they pull out, and the sleeve on the back just slides off also? I also see the seatbelt retainers on the seat box are fixed in a similar fashion. I need to replace the carpet under the front seat already as its sobbing wet and stinks!! Got the carpet for £45 from the stealers. Removing front seat looks straightforward just those bloody trim pins baffled me!! Had a good look at the carpet from the dealers and what cheap crap it is.
Post #82085 26th Jul 2011 10:10pm
