Home > Maintenance & Modifications > Carpet Trim Question |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Martyn
They are reusable if you remove the black pin with care. I use a trim removing tool on the black pins, it pushes down on the plug and stops it getting damaged. Bob |
18th Jul 2011 7:25pm |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 |
Martyn,
Unfortunately I did the job first and then asked questions That means I damaged the plastic cups when I removed the black pins. A nice tip from a fellow here is to put some vaselin or grease inside the cup in order to be easier to pull off the pins if needed in the future. Mike |
21st Jul 2011 11:44am |
you can get replacements from LR and halfords (in the UK)
21st Jul 2011 8:03pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
I've chosen to lose the carpets under the mats. They sponge up moisture and pi55 me off. Much less hassle with just the LR rubber underfoot.
21st Jul 2011 8:07pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
i second that, no carpets since my first time off road, we did get more than a couple of inches of water in the cab 1200 miles on the clock and people thought i was daft. |
22nd Jul 2011 10:10pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Thanks for that Mike. I take it they pull out, and the sleeve on the back just slides off also? I also see the seatbelt retainers on the seat box are fixed in a similar fashion. I need to replace the carpet under the front seat already as its sobbing wet and stinks!! Got the carpet for £45 from the stealers. Removing front seat looks straightforward just those bloody trim pins baffled me!! Had a good look at the carpet from the dealers and what cheap crap it is. |
26th Jul 2011 10:10pm |
