Home > Camping, Caravanning and Holidays > Gooseneck air suspension trailer
OK, maybe not applicable to towing in the UK, but looks an interesting idea; and I wonder if it has any elements that could be of benefit to us?
Post #819983 17th Mar 2020 2:39pm
L110CDL
I watched the full length of the video and as you say it is a very interesting idea and maybe others will/might start to think this way and could develop uk trailers in some way Thumbs Up Clayton.
Keeper.
Post #820144 18th Mar 2020 8:19pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Not sure if talking about the “air ride neck” or the 5th wheel element?
But a pal of mine had this built & uses it in his business, handy bit of kit!
Post #820153 18th Mar 2020 8:48pm
excossack
What advantages are there with the type of trailer setup (apart from airbag suspension to smooth the ride out) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #820193 19th Mar 2020 7:58am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
5th Wheel attachment point max permitted load is significantly higher than max permitted conventional tow ball load as such the trailer wheels can be much further back, more akin to an agricultural trailer and much better manoeuvrability. The 5th wheel load also applied directly over the back axle aiding load distribution on the towing vehicle.
This set up is extremely popular in North America and Canada where they have pick-ups with real world load carrying capabilities much larger than the 1Te Pick ups we see in Europe. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #820204 19th Mar 2020 9:13am
I was just thinking about the particular arrangement of the air bags, as opposed to just using air bags per se.
Your pal's setup looks interesting - is there not a licencing issue to using such an arrangement in the UK that means it's not going to be used by more than a few people?
Post #820206 19th Mar 2020 9:19am
excossack
Cheers. How much higher in terms of weight?
The USA/Canadian programs I have seen hauling 70's tractor units on trailers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #820224 19th Mar 2020 11:26am
ickle
Surely that trailer can only be 3.5 tonnes gross or possibly 4.0 tonnes if its got c coupled air brakes?
Post #820263 19th Mar 2020 6:40pm
The limit will be the manufacturer's max towed weight and gross train weight for the pickup. It looks like a Navara, so it probably is 3.5 tonnes.
You could in theory go heavier but you'd need a towing vehicle with greater plated weights, and that would take you into HGV territory (you'd need a CE licence, O licence, etc).
You have to use couple brakes with a gooseneck, of course, and US-style electric systems are I believe not allowed in the EU/EEC/UK. They'd have to be air.
Post #820268 19th Mar 2020 7:51pm
ickle
So top car guess 1500 kg, bottom car 1650 kg, trailer minimum of 1100 kg, bit overweight?
Post #820269 19th Mar 2020 8:10pm
Unless the Navara's been upgraded and up-plated.
Post #820271 19th Mar 2020 8:33pm
DSC-off
Two, or sometimes three, of these on a trailer will be considerably more than 4 tonnes.
That air suspended trailer will make it difficult to load the third one, or more commonly a SxS ATV, on a platform directly above the gooseneck.
Yes, he was overtaking us, going uphill.
A Ford F-250 with the 6.7 L V8 'Power Stroke' turbo diesel, 475hp, 1050 lb-ft torque has a 5th wheel towing capacity of 22,800 lbs. If it's any ordinary trailer that drops to only 20,000 lbs.
Most large pickup trucks will have options competitive with that.
Post #820301 19th Mar 2020 10:41pm
^^^^ Liking that. Thumbs Up KEEP CALM AND Drill ON
Post #820305 19th Mar 2020 11:50pm
