Home > Camping, Caravanning and Holidays > Gooseneck air suspension trailer |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10756 |
I watched the full length of the video and as you say it is a very interesting idea and maybe others will/might start to think this way and could develop uk trailers in some way 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
18th Mar 2020 8:19pm |
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 |
Not sure if talking about the “air ride neck” or the 5th wheel element?
But a pal of mine had this built & uses it in his business, handy bit of kit! Click image to enlarge |
18th Mar 2020 8:48pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
What advantages are there with the type of trailer setup (apart from airbag suspension to smooth the ride out) 1999 Defender TD5 110
19th Mar 2020 7:58am |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 678 |
5th Wheel attachment point max permitted load is significantly higher than max permitted conventional tow ball load as such the trailer wheels can be much further back, more akin to an agricultural trailer and much better manoeuvrability. The 5th wheel load also applied directly over the back axle aiding load distribution on the towing vehicle.
This set up is extremely popular in North America and Canada where they have pick-ups with real world load carrying capabilities much larger than the 1Te Pick ups we see in Europe. 130 Puma HCPU with an Artica 240LR Demountable Camper |
19th Mar 2020 9:13am |
I was just thinking about the particular arrangement of the air bags, as opposed to just using air bags per se. Your pal's setup looks interesting - is there not a licencing issue to using such an arrangement in the UK that means it's not going to be used by more than a few people? |
19th Mar 2020 9:19am |
Cheers. How much higher in terms of weight? The USA/Canadian programs I have seen hauling 70's tractor units on trailers. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
19th Mar 2020 11:26am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Surely that trailer can only be 3.5 tonnes gross or possibly 4.0 tonnes if its got c coupled air brakes?
19th Mar 2020 6:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17383 |
The limit will be the manufacturer's max towed weight and gross train weight for the pickup. It looks like a Navara, so it probably is 3.5 tonnes.
You could in theory go heavier but you'd need a towing vehicle with greater plated weights, and that would take you into HGV territory (you'd need a CE licence, O licence, etc). You have to use couple brakes with a gooseneck, of course, and US-style electric systems are I believe not allowed in the EU/EEC/UK. They'd have to be air. |
19th Mar 2020 7:51pm |
So top car guess 1500 kg, bottom car 1650 kg, trailer minimum of 1100 kg, bit overweight?
19th Mar 2020 8:10pm |
Unless the Navara's been upgraded and up-plated.
19th Mar 2020 8:33pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1408 |
Two, or sometimes three, of these on a trailer will be considerably more than 4 tonnes.
That air suspended trailer will make it difficult to load the third one, or more commonly a SxS ATV, on a platform directly above the gooseneck. Click image to enlarge Yes, he was overtaking us, going uphill. A Ford F-250 with the 6.7 L V8 'Power Stroke' turbo diesel, 475hp, 1050 lb-ft torque has a 5th wheel towing capacity of 22,800 lbs. If it's any ordinary trailer that drops to only 20,000 lbs. Most large pickup trucks will have options competitive with that. |
19th Mar 2020 10:41pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
^^^^ Liking that. $W33T $0U7H3RN $UG4R
19th Mar 2020 11:50pm |
