Home > Technical > No voltage on pin 9??? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 |
Is it a genuine LR 13 pin electrics pack or aftermarket? Genuine will have LR logo on the socket cap. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
15th Mar 2020 8:22pm |
Black90 Member Since: 24 Nov 2013 Location: Western isles Posts: 8 |
Thanks for reply.
No, it doesn’t appear to be. The socket cap hasn’t got anything on it. It was already on the vehicle when I acquired it. |
15th Mar 2020 8:58pm |
Pin 13 is the earth connection for pin 9 which is the permeant live which will not show up as faulty under normal towing. I have seen what some installers do if the socket does not have the manufactures connectors fitted which is to either fail to connect pin 13 if only used for trailer sockets or bridge the other earth pins together in one connector which is too small leading the three earths cable's fall apart. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
16th Mar 2020 8:41am |
Check Fuse 2 in the seat box fuse box (20A), also the single pole connectors with fat purple cable near the brake servo. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Mar 2020 10:17am |
Martin many thanks for your Reply and suggestion checked fuse 2 (20amp) in the under seat fuse box and it had blown replaced and my Ctek battery charger using my tow adaptor is now working and seeing the battery . Very much appreciated 👍
16th Mar 2020 4:15pm |
Awesome 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Mar 2020 7:08pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
It's always great to know when a problem has been solved and what action was taken to solve it. Looks like Martin has come up trumps again. Defender 90XS SW
16th Mar 2020 8:24pm |
