Home > Maintenance & Modifications > superpro bush into upper rear shock absorber mount....
donmacn
Hi,
My "fun" for the last 45 mins or so has been trying to fit a one piece superpro bush into the top of the rear shock....
It's the 'standard' superpro bush for this location on a Defender, but I have Old Man Emu shocks.... are the two compatible, or do OME shocks have a bespoke/proprietary bush?
Basicially trying to figure out if I'm trying to do something that's not possible?
They look they would be compatible IF I could get the bush in, but that's just not happening. I don't have a press, but I am using a vice and the outer diameter of the bush just will not slot into the shock.
Any advice gratefully received... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #819579 14th Mar 2020 11:57am
donmacn
Well, in case anyone else wonders and wanders this way, I'll answer my own question.
The eye at the top of the Old Man Emu shock is quite a bit smaller than the standard one. I'd estimate about 8-9mm in overalll diameter.
What a pain. I think it would be a good idea to highlight and call out the brands that do this. Yes, there's an argument that one should check - but for something like this they should just use what's standard.
I know OME is a brand I won't buy again, on this basis.
OK, rant over. Donald
in the past..
Post #819597 14th Mar 2020 1:15pm
ibexman
Try some lube
Post #819601 14th Mar 2020 1:50pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
said the actress to the bishop
Post #819619 14th Mar 2020 5:27pm
donmacn
Smile indeed. Unfortunately I've already tried that. In fact I tried that from the beginning. Superpro bushes come with the little sachet of silicone grease so I was using that anyway.
The difference in size is just too much to get the bush started into place. I even thought of a jubillee clip to compress it down a bit, but that didn't work either.
Going to see if I can get OME bushes separately as a first solution, then see where I go from there. Donald
in the past..
Post #819642 14th Mar 2020 7:29pm
DSC-off
I believe in the bush size changed at some point (around 1990?) on factory fitted shock absorbers.
Either shock absorber will fit earlier or later vehicles, provided it has the bush it was intended to be used with.
The problem isn't really down to OME, they don't want to have to supply the same shock with 2 different size eyes and bushes, when one size works fine.
It is possible to get the smaller polybushes from most manufacturers. I'm currently using Britpart yellow ones on my Ibex and have 2 sets of larger bushes on the shelf in the garage, poly and rubber, from before I discovered the difference. Embarassed
Post #819672 14th Mar 2020 9:37pm
donmacn
cheers, it's definitely my day for grappling with how parts have changed slightly over time.
... and good to know i'm not alone Smile Donald
in the past..
Post #819676 14th Mar 2020 9:54pm
