Home > Maintenance & Modifications > Shaggydogs Running Restoration |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Good Suggestion, Some fairy liquid may help too!
Just make sure its dry before putting any power through it Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
16th Feb 2017 1:16pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
Nothing like a bit of lube
16th Feb 2017 1:43pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1721 |
Been a while since ive been on here but always like to see whats going on.
Sorry to hear about the hassle you've had. Personally though i'd of been chuffed at the result with the payout (not the wasted time though) If you want details of the very good painter Ii use in Essex feel free to drop me a pm. He used to own defenders and has done all the work on my cars. Cheers Tom Defender puma dormobile camper |
16th Feb 2017 3:21pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
Spend 3.5k on paint ? Out with a roller and a tin of coach enamel and give it some character. Then buy some nice goodies for it with the 3.4k left over. 😊
16th Feb 2017 7:09pm |
Thanks for the offer Tom
The money is ok, would rather have not been in this situation but hey ho! they hardly covered themselves with glory.... For now I have some rough waters ahead of me so the money is being kept to one side as a shiny painted defender wont pay my rent.... so we shall see what happens. Retro, when I replaced the bowls I bought the wrong ones and had wanted the bowls with the removable bung at the back. They are on the list of things to change but for now its a fairly low priority. Where did you get your ones from concededly? Mo, ha! I would love to do a proper coach painted finish but I fear my painting skills are not what they once were. I have a good idea of what I want to end up with. Just need to get some ducks lined up at the moment. Not much has happened since I got her back. I wanted to change the alternator but didn't realise that in order to run the uprated cable to the starter motor you have to drop the exhaust, webasto exhaust, and possibly intake manifold to get to it. That job has been parked for now but will hopefully come back into focus next month. That coupled with the rising price of diesel has put me off the road for the last few days as 15 a day on train tickets is cheaper than fuel. Something has to change and change soon Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Feb 2017 1:12pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2645 |
I can't remember where I got the bowls from. However I recently replaced them as I stripped one of the adjuster threads and couldn't get open-backed ones so just cut my own hole in the back instead.
Yours is a 200Tdi isn't it? It should be doable to run a new cable from the alternator to the starter motor without removing all that stuff - probably from underneath for the last bit. If you can't get to the starter motor terminals then just run it to the battery instead. The factory wiring goes right round the other side of the engine to avoid the exhaust, which can just stay in place. Move closer to work? Anything to avoid using trains! |
17th Feb 2017 2:43pm |
Good point about the hole! I might be able to find a grommet with a hole in the middle which I can shimmy it through so it retains some waterproofness.
It is indeed! The wire supplied is enough to follow the original route. I think if I drop the exhaust down I should have enough room to attach it onto the starter terminal. Problem is I have big hands and with the webasto gubbins in the way its a bit tight on space. I can have a tennis match on the other side of the engine mind! Plans are emerging but were not moving as we love where we are for now. But soon enough something will change, just waiting on some ducks to line up before I pull the trigger Its not so bad using the train, its just....eh. Plus I don't mind queuing in traffic as I can usually route around it. When its raining and you have heard the announcement say" The next train is delayed by 20 minutes, Southeastern apologies for the inconvenience" for the 8th time it gets a bit thin. Though at least its a better service than Southern Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Feb 2017 1:28pm |
So progress on my 110 has been somewhat slow.
For my sins she has been in storage for the last 2 years and unfortunately remains so. After the complete cluster-fudge of how I was treated and the damage done to my girl it caused all sorts of issues which culminated with her going into storage. As well as quitting my job, buying a Volvo (Never Again ) doing truck driving for a while, scrapping the Volvo and buying a Ford Ranger (great truck ), ending up doing a few weeks of heavy recovery and then moving house, getting another job and a dog. Who asked?! I hear you cry! Well nobody, which is fine I'm just building a picture of why I haven't been around much. So, having been thoroughly mucked about and "Rogerd" so to speak by LR I was left in a situation where I had a load of bits for my truck but nowhere or way to fit them. This included bits of trim, doors, lights all sorts of nonsense which I had been assured would be fitted but in the end was told nah jog on. The doors most notably were a set of S&P Galvanised ones which since buying I have reluctantly had to store in my damp cold shed. Until a couple of days ago.. With trepidation I loaded the boxes into the back of the ranger and took them to work so they could be assessed for painting. Bearing in mind I had not opened the boxes in over 2 years I was half expecting to pull them out and find them bright red rusty and useless. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Well the results speak for themselves! Over the moon they have not got a speck of deterioration on them and should (fingers crossed) be heading into paint at the end of the month. I can whole heartedly recommend them if your thinking about replacing your doors use these ones, they are cracking! So hopefully here marks the start of getting my rolling restoration rolling again. Now just need to split my time between gundog training, shooting, gardening, work, rebuilding my truck as well as rebuilding and looking after these lumps.... Can always sleep when your dead Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
13th Mar 2020 3:44pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
13th Mar 2020 4:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17377 |
Welcome back!
13th Mar 2020 4:13pm |
Very glad to be back!
Will be even happier when I'm listening to her rumbling along again Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
13th Mar 2020 4:23pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
Watching with interest!
13th Mar 2020 7:00pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10751 |
Great to have you back Shaggy
I like those big lumps that you have to look after 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
13th Mar 2020 7:57pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3498 |
As Clayton says, I like those lumps 👍
I can’t believe it has been so long. Welcome back |
13th Mar 2020 8:05pm |
