Home > Technical > Gear lever movement?
ChrisDefender
Hi all,
Just had the gear stick out to glue the weights, but there was no rattle at all from them, so I put it back without gluing, after great pain to my hands! Eventually had the matting up to get the gaiter back on ☹️
Anyway, read the post again and I’m now not sure if I should have glued them anyway in case it’s the vibration of the gears that causes it rather than me just shaking to try and hear them. Trouble is I don’t know what I am listening for?
So, question is:
If I can’t hear a rattle from the weights in my hand are they OK, and
Should the gear stick have a bit of up and down movement after replacing, I made sure the clips were clipped in properly.
Any info appreciated Bow down
Cheers.
Post #818917 9th Mar 2020 3:28pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Chris,
I had an intermittent small vibration noise from my gear lever.
I don't remember any weight movement or noise after I removed the lever. I just glued it as described. Gearstick vibration noise was caused by engine vibration. This cured my problem anyway. It was an easy job, just left the stick off overnight for superglue to dry properly.
Not sure if this helps but thought I'd share.
Chris
Post #819023 10th Mar 2020 12:57pm
ChrisDefender
Hi Chris
Cheers. Looks like I will have to take it off again and apply some glue Confused and go through the pain of getting the gaiter back on!
Cheers, much appreciated.
Post #819043 10th Mar 2020 5:10pm
ChrisCSL
No worries.
As a side note. I didn’t have any problem with the gaiter. Just lifted it up over the top of the stick and when putting back, going underneath from bottom through gaiter. Not sure if that’s what you did. Probably stating the obvious.
Anyway best of luck Sir.
Chris
Post #819051 10th Mar 2020 5:51pm
It is entirely possible to push the gaiter down below the gear lever attachment, then ease it back up afterwards, which saves disturbing the mats/carpet and freeing it from the transfer lever.
In the course of developing my "heritage knob" I have done this many times of late!
Post #819052 10th Mar 2020 5:58pm
ChrisDefender
Cheers.
Black wolf, that’s what I tried to do, but either I am useless or my technique was very poor! Very Happy Either way the pain was unreal. Hence I resorted to lifting the matting and going up underneath Very Happy
I will save the job for when I have some patience in the bank!
Cheers all. Bow down
Post #819054 10th Mar 2020 6:04pm
ChrisDefender
Part of the problem is I don’t really know what noise I am listening for! I definitely have a rattle from that area or somewhere close, but I just cannot track it. Confused
As I have learned, trial and error works in the end!
Post #819055 10th Mar 2020 6:19pm
RILEY
United Kingdom 1994 Defender 90 Td5 CSW Stornoway Grey
I agree with you, that gaiter around ....Is an absolute Ars0le !!!!
placed it in hot water
piece of cake its just seasoned ,needs tweaking Laughing Laughing Laughing one life, sell it
Post #823197 3rd Apr 2020 6:28pm
Do you mean movement whilst stationary or on the move?
There is general engine movement at idle in neutral, (vibration mainly,) if it's on the move and you've noticed a recent difference then I'd get your Propshaft UJ's checked as I found that this was when I had a problem with a UJ.
Usually more pronounced at slower speeds.
Another scenario is that the Nylon ball joint is cracked or degraded, I also had this and couldn't see it was broken until removed for greasing.
I now have the Shift-R V2 instead from TMD which do far has been brilliant and nicely greased too.
This is at about 74k miles or so. TheThunder Rolls🇬🇧🇺🇸
Post #823202 3rd Apr 2020 7:02pm
RILEY
Think he's struggling with the arseh0le gator tbh /plus possible other issues
bit of rubber water hose around the lever ,cures all
Ah back to the series days Rolling with laughter one life, sell it
Post #823208 3rd Apr 2020 7:13pm
ChrisDefender
Hi, when stationary there is a very slight movement or lift vertically, maybe only a few mm or so.
I think I need to looking the Shift-R! Cheers.
Post #823297 4th Apr 2020 2:52pm
