Home > Puma (Tdci) > Advice with heated front screen?
Smilesapart
My 2014 110 has the heated front screen, however I can’t tell if it’s actually working or not at I haven’t had a misted up screen yet! However I know the windscreen was recently replaced just before I bought it. The question is: should there be a warning light picture of the front screen come up on the warning light panel when it is switched on? Because there is when I switch on the heated rear window, but not with the front one.
So could someone with a heated front screen tell me if there’s when switched on shows a warning light for it? Thanks.
My gut is telling me this isn’t working and I need to know before it’s warranty expires
Post #817180 27th Feb 2020 9:01am
No, there isn't a dash warning light for the front heated screen. Only the telltale on the button. Darren
Post #817190 27th Feb 2020 10:01am
Martin
Site Admin
As LRA says, only the orange LED on the button itself. If this is on, the timer and relay are providing the 12V feed to the screen.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #817199 27th Feb 2020 10:37am
ericvv
Just take a cup of very hot tea into your truck, hold it close to the windshield to let it mist up, and see if you turn on the heated screen if it will demist quickly. Do this test in a few spots left to right as it is known that sometimes certain portions of the electric heating wires inside the screen will fail. You can afterward even still drink your cup of tea if you like. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #817205 27th Feb 2020 11:37am
jst
put the tea at one end so you can see the difference between the working part and the edges of the screen where there are no wires!
how can you live in the UK and not know if its not working through not having the need! snow and frost here testing mine currently. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817207 27th Feb 2020 11:43am
Smilesapart
Rolling with laughter I live in the ‘California’ of the UK - Suffolk and at night it’s under cover so it’s not been cold enough to give me the chance to test it! I drive it daily.
I’m going to do the tea test! As yes the putting does light up and go out after about 10 minutes
Post #817212 27th Feb 2020 12:24pm
AMBxx
Surely it could be tested with a multi-meter? Or, is the current draw not enough to pick up?
Post #817221 27th Feb 2020 2:19pm
ericvv
Post #817229 27th Feb 2020 3:10pm
CSK
France 2016 Defender 90 V8 Petrol Works V8 Auto Indus Silver
Will check if the heated screen works upon departure from the French Alps on Saturday early morning. Smile
Never had the opportunity to check before in St Tropez! Smile
Post #817282 27th Feb 2020 8:51pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Heated screens are good, but perhaps not that good Laughing
Post #817311 27th Feb 2020 10:51pm
