Home > Maintenance & Modifications > Halo Drls.. |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
The appropriate Live is the feed for each headlight or indicator or sidelight element that he wants to pick up, so indicators need chipping in to the appropriate loom on each side.
If you want the DRLs to come on with the ignition then you need an ignition live. I believe that there is an IG live that runs to the heater motor but best to have a look on a wiring diagram. |
24th Feb 2020 9:04am |
This thread: https://www.defender2.net/forum/post628236.html
This Bit:
24th Feb 2020 9:06am |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1384 |
Cheers will let him know. Putting Dreams on Drives at JLR Solihull..
24th Feb 2020 9:16am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2527 |
Heater motor is an AUX live and not an IGN live Defender 90XS SW
24th Feb 2020 9:48am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Indeedy. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Feb 2020 10:19am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2230 |
If he runs the ignition live for the DRLs through a normally closed relay and then triggers it open with the sidelight feed then the DRLs will switch off with sidelights.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
24th Feb 2020 11:42am |
