Home > Puma (Tdci) > Under bonnet seals
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Under bonnet seals
Hi any one know the part number or where to get the under bonnet , near the bulkhead seals
 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #815917 18th Feb 2020 11:08pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Can’t remember the part number but I bought it from the dealer. Unless you insist on avoiding the dealer at all cost they won’t cost you a lot.
Post #815920 18th Feb 2020 11:39pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Due you mean the short seal on the wing next to the bulkhead?
If so it’s P/N LR038612
Post #815923 19th Feb 2020 5:35am
natyeo
Thank you 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #815943 19th Feb 2020 8:23am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Funny, I bought my MY2009 90 2.4 new, and there is no such seal on mine (maybe because it's LHD? None of the LHD ones I've seen have that either)
I've ordered one for each side, always thought something was missing there! Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #815972 19th Feb 2020 10:08am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
My LHD has them. One was about to fall off however, so I put some dumdum inside so they stick to the wing.
Post #815980 19th Feb 2020 11:43am
My 2007 Puma has never had them. Do they do anything useful?
Post #815987 19th Feb 2020 1:03pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
they stop (...or at least reduce) water cascading down from the wing tops onto the bulkhead in engine bay in torrential weather.
I added a second one and stopped the ingress via the blower gap
https://www.defender2.net/forum/topic47380-15.html
Post #816014 19th Feb 2020 4:42pm
macfrank
yep. I've also put some dumdum underneath the gap between wing and bulkhead.
Post #816016 19th Feb 2020 4:51pm
Hmm, I've never found the former to be a problem, and I have a properly fitting heater duct, so I guess the answer to my question is "no"!
They seem to be rather expensive for what they are. I guess if I managed the last 12 years without knowing that I needed a pair, I probably don't!
Post #816083 19th Feb 2020 11:06pm
macfrank
Thumbs Up
did you watch the video from minute 12:00 to 13:00? 'orrible Shocked
Post #816092 20th Feb 2020 6:08am
No, since personally I find that fellow completely insufferable (not intended as a criticism, please note).
Post #816104 20th Feb 2020 8:16am
