![]() | Home > Puma (Tdci) > Clutch....problems |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
In your case the slave cylinder is located on the left side of the bellhousing about half way up. Sounds like air in the line. Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
If it's a Puma the slave cylinder in inside the bellhousing - it's an annular unit round the gearbox input shaft and to access it you have to remove the gearbox/transfer box assembly.
The object on the outside is the return flow regulator in the hydraulic line (provided to protect the transmission due to the reaction of the anti-stall if your foot slips off the pedal). If the clutch suddenly gets light but still works I would initially suspect the pedal return spring, but I am not sure why it would then go back to normal. |
That sounds like a great way to complicate a repair job - I can just imagine having to remove the gearbox in the middle of Africa just to repair a knackered slave cylinder ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
