Home > Puma (Tdci) > Clutch....problems
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Clutch....problems
Hi
Today as I was driving - my clutch suddenly changed. The pedal felt very light - and the clutch engaged when it was just a few cm from the bottom. I pulled over and checked fluid - all ok. Driving along again it changed from ok to "light" and back again - now after 100 km everything is ok again?? What to do Confused - if anything. Is the slavecylinder situated inside? I still have the original clutch...55.000 km.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #81280 20th Jul 2011 9:00pm
MK
In your case the slave cylinder is located on the left side of the bellhousing about half way up. Sounds like air in the line. Puma 110" SW
Post #81370 21st Jul 2011 10:23am
If it's a Puma the slave cylinder in inside the bellhousing - it's an annular unit round the gearbox input shaft and to access it you have to remove the gearbox/transfer box assembly.
The object on the outside is the return flow regulator in the hydraulic line (provided to protect the transmission due to the reaction of the anti-stall if your foot slips off the pedal).
If the clutch suddenly gets light but still works I would initially suspect the pedal return spring, but I am not sure why it would then go back to normal.
Post #81376 21st Jul 2011 11:28am
JSG
That sounds like a great way to complicate a repair job - I can just imagine having to remove the gearbox in the middle of Africa just to repair a knackered slave cylinder Rolling Eyes John
2011 Tdci 110 CSW XS
Post #81397 21st Jul 2011 1:06pm
