![]() | Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2934 ![]() |
So to continue the road to a factory finish exterior I needed to think about the zunsport grille. The Lazer ST4's are just too good to remove so last night took a few measurements and came up with a plan. Found a local mate that had a standard grille so collected this and then carefully started to Dremel the openings for the lights. This took me close to 3 hrs to get the grille to slide over them both nicely. Rather than drill out the filled surround I just added some black vinyl so the white didn't show and then was able to add some small black clips to secure it.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I also then made some extension brackets so that the Lazers could move out flush with the grille. ![]() Click image to enlarge Really pleased with the results, ordered a new LR badge for it and just need to get it painted Santorini and then I can also think about adding the headlight surrounds after the wings get re fitted. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Cracking handy work
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3800 ![]() ![]() |
Very neat π
Did you consider hiding them under the lower a/c grille Either way looks factory π |
That would have needed a lot more work. This way the lights are still all secure to the zunsport grille and the standard Grille is just sitting over. I could remove the mesh but itβs quite nice in behind and no point destroying the Zunsport grille Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
You can really see the wing mis alignment in this picture
![]() ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
One of the first mods I did to my 110 was align the wings properly
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Even though itβs all coming off soon I think I will get some washers tomorrow just to see the difference, is it just the one bolt you space out? Seen it just behind the aircon rad. Andy
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3788 ![]() ![]() ![]() |
Hello again, here is an example of an Aussie conversion I thought you may like.
&feature=youtu.be&fbclid=IwAR01lJTrfgjQI58ILcEKStkUOq4zfNpfOH2DznbJZjus3bv38nFjYAfDHHI You might want to "mute" the music, it's pretty average. Regards, Pickles. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
That is very very tidy and looks fantastic
![]() 2008 SVX 90 2000 XS TD5 90 |
Thanks,
Out of interest what the best way to host decent quality images now and get them onto the forum? I load them to the gallery and then insert but they seem to drop in res? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Res is plenty good enough to make me very jealous!! Grille with Lazers look great! James
Thanks James, I am in the garage tonight wrapping, had to get some supplies in
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Delivery from Croytec, quality as always top class.
![]() ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
