Home > Maintenance & Modifications > Winch recomendations
Eduardo
Hi there!
Some recomendations for a Winch for the Defender SW 110?
Installations tips?
We will not use so much, just in some ocasions in my wife's work trips to the forest (quite muddy in winter) or in the farm as a tool.
Just an idea possibly to be developed in the next months (depending of the funds)
Thanks! Eduardo
Post #8134 6th Mar 2009 12:12pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Highly recomend the Warn Powerplant HD as its an excellent winch and a great compressor built in Thumbs Up
Post #8139 6th Mar 2009 1:24pm
DAZ110
I always wanted one of the hydraulic winches.
Alfred murry supply or is it 4x4winches.com?
Daz110
Post #8142 6th Mar 2009 2:10pm
mse
I cant help but say anything with a warn logo on it.
I have a 9.5ti Mike
Post #8148 6th Mar 2009 5:00pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
100 % agreed, Warn all the way. if it is going to rarely be used, its more of a reason to have Warn - so reliable it's always there, even when not often used. We also have 9.5ti's, no problems from any of them, also got the dynaline and aluminum fairleads. Great bit of kit! Thumbs Up
 110 Tdci Double Cab
Post #8184 8th Mar 2009 12:23pm
Glynparry25
I am going for a Superwinch Husky (have one ready to fit) as they are bulletproof. Only down sides are the price and you do have to give it a working every couple of months- but hey, at least if you get stuck you know it is going to work.
Glyn
Post #8188 8th Mar 2009 2:11pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Have been running an XP for yonks. Built like a tank, never failed and will pull 2 Landies out of a mud hole with one tied to the other.
Nice thing with the XP is the seperate winch electronics box, which you can relocate anywhere on the vehicle, therefore reducing the winch profile. It also means that if something happens with the electronics box, you an just take it off and take it apart without having to take the whole winch out. You can even keep a spare handy!!
I not only moved the box to the inside of the engine bay, well up high under the wing, but also detached the actual part where the remote plugs in and extended the wires. That way you can mount that bit anywhere you want, even inside the vehicle should you desire!! My plug is mounted on the panel that holds the headlights in place.
Would DEFINITELY recommend the XP. It also has the extra grunt (6hp, rather than the usual 4.6hp).
I would also say, get a winch for what you need. Dont go throwing money away on a serious bit of kit like an XP or any other comp winch unless you really need it. For a lot less money, but actually made by Warn, you can get the Tabor 9k, which is an excellent piece of kit for half the price. Same parts etc and assembled and even comes out of the Warn factory!! Has slightly thinner walls (on the metal bits), but that is not really a problem. Dont get too hung up on the name thing. Dont get me wrong, Warn are excellent, but for the odd bit of use now and again, you really wont notice any difference.
Huskys are good, but a lot slower, but they will pull a house out the ground and will NEVER go wrong.
Hydraulic is good for a winch that you will use everyday, but for general LR use, get an electric one.
Some of the superwinch gear is really good too, but dont bother with Britpart. T-Max are ok, but of the three, Superwinch would get my vote.
Warn Ti, Si etc are good, but are really designed for heavy use where the thermometric kit etc will actually operate, but I doubt for what you describe you will need it.
To summarise, for the use you have described, I think the Powerplant would be overkill as you dont seem to need the functionality of a compressor as well, (would be very handy on an expedition or working vehicle though!!), so I would recommend something like the Tabor 9k which will be very sufficient and will give you many years of trouble free use. One of the reasons that companies dont often recommend them or stock them is because the mark-up is not as high, so they dont make as much profit. Devon 4x4 stock the Tabor and at a good price and I highly recommend their service.
Best of luck in your decision.
Landy nut
Post #8193 8th Mar 2009 4:13pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
I have a husky winch Rolling with laughter Rolling with laughter check my gallery, sorry not sure how to post pics.
Post #8205 8th Mar 2009 8:59pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Nice winch, a bit high maintenance though. 130 crew cab
98 V8 Disco
Post #8211 9th Mar 2009 12:17am
foz.in.oz
Australia 2004 Defender 110 Td5 SW Bonatti Grey
Do they coil up under the bumper when not in use? Laughing Laughing Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG
Post #8212 9th Mar 2009 12:45am
AndrewS
Post #8239 9th Mar 2009 3:25pm
Eduardo
Thanks a lot for all the help.
Well 9.5 XP looks a little bit expensive here in Chile (almost US$2,000 Shocked compared the US$1,000 in USA)
So, looks like Tabor will be a good decisión (if it si reliable) any experience with it?
Anyway, pretty nice Husky winch Laughing Laughing Laughing Eduardo
Post #8240 9th Mar 2009 4:21pm
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
Rolling with laughter i think your husky winch is loosing fluid on the 3rd cylinder though Whistle Rolling Eyes
Post #8243 9th Mar 2009 4:55pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
28 paw power can't fault it Laughing
4 paw drive NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8244 9th Mar 2009 4:59pm
markalpha
Thanks for that Andrews.
Post #8254 9th Mar 2009 8:37pm
