Home > Maintenance & Modifications > Winch recomendations
Page 2 of 2 <12
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Eduardo wrote:
Thanks a lot for all the help.
Well 9.5 XP looks a little bit expensive here in Chile (almost US$2,000 Shocked compared the US$1,000 in USA)
So, looks like Tabor will be a good decisión (if it si reliable) any experience with it?
Anyway, pretty nice Husky winch Laughing Laughing Laughing
The XP is pricey, but excellent, but will be overkill for what you want. Tabor also do a 12k too if you fancy some extra grunt. Both available from Devon 4x4. About £530-580. As they are made by Warn in the same factory using Warn parts, they should be equally as reliable and well built. Look after it well, keep the parts clean and keep the wire dirt free and you should not have any problems.
I cant honestly imagine Warn selling these if the quality was below par, especially with people knowing who they are made by. There will be a couple of slightly different parts (thinner walls etc) to reduce some costs, but it does not have the Warn label on it, which means you will automatically get a substantially reduced price. Its a bit like many other products. Its a bit like the Tudor and Rolex scenario.
One other thought will be availabilty. I have just noticed where you live. You will want to do some looking around first to check what is available to you. You might also want to look at shipping costs, as a winch is a very heavy item that will cost quite a lot to ship and insure.
Thinking of the price difference, could you not buy one in the USA and have it shipped straight to you? That way you could afford a Warn.
Best of luck
Landy nut
Post #8257 9th Mar 2009 10:31pm
alantd
Alex e wrote:
Rolling with laughter i think your husky winch is loosing fluid on the 3rd cylinder though Whistle Rolling Eyes
Number 4 cylinder looks like it is about to throw a rod Embarassed One that started out as a 2.4 TDCi 110 XS
Post #8263 10th Mar 2009 6:06am
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
The 'winch' had just done a hard working run and consumed alot of water after the run and the girlies just let go!. The boys need something to pee on.
Can be high maintenance esp now girls are in season boys just want to f**k.
Foz they do like to coil up under the bumper and sleep or destroy things!
Post #8271 10th Mar 2009 1:10pm
Eduardo
Landy nut
Thanks for the advice a Tabor will be,
I allways compare the prices here with the prices of import from USA. Some times is cheaper here and others are cheap in USA. In this case the problem will be the price (I will need a custom agent to clear the customs) and the weight that not allow use some cheap couriers or my PO box in USA.
We will see. At least i have almost clear what I need.
Cheers Eduardo
Post #8276 10th Mar 2009 2:43pm
El Cyd
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Winch Recomendations
only one Fit a cut out switch if it doesnt come with one buy and install before you use the damn thing.
trust me on this its worth it If it aint broke its just waiting.
Post #8332 11th Mar 2009 10:23pm
El Cyd
Post #8333 11th Mar 2009 10:23pm
Eduardo
Thumbs Up
Thanks El Cyd Eduardo
Post #8418 13th Mar 2009 10:00pm
El Cyd
My pleasure If it aint broke its just waiting.
Post #8824 22nd Mar 2009 8:57pm
Page 2 of 2 <12
