Home > Maintenance & Modifications > Transfer Box and Diff Oil |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello DerekV
Check out the Castrol recommended Oils here... https://applications.castrol.com/oilselect...2011-2016) Click on Next (on Castrol's web page) to get to the Transfer Box... SKIP https://www.defender2.net/forum/topic83242.html |
29th Jan 2020 6:20pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4218 |
I asked Opie Oils and they recommended a Millers Nanodrive GL4/5 that could be used throughout the whole transmission. 2007 110 TDCi Station Wagon XS
29th Jan 2020 6:29pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
I’ve got Millers CRX 75w90NT+ (GL4 & GL5) in my Gear / Transfer box and Diffs.
No driveline noise at all on the motorway. |
29th Jan 2020 7:29pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Engine oil spec for 2.2 w/ DPF: 5w/30 WSS-M2C934-B
Gearbox oil spec: Ford WSD-M2C200-C Bot130 or Bot328 the replacement. Available from LR. Transfer case oil spec: SAE 75w/90 or sae 80w/90 api GL5 Diff oil spec: EPX 80w/90 or any old cooking oil you have laying around!!! I use Fuchs Titan GT1 pro c-1 in the engine LR Bot328 in the trans Castrol syntrax synth GL5 75w/90 in the T-case Castrol epx 80w-90 in the diffs HTH! 2014 Keswick Utility 2.2 |
29th Jan 2020 7:52pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
MY advice.
Cheap stuff in diffs. They are very basic units, don’t get exceedingly hot, and are easily changed. Get the best stuff you can find for your transfer box. It’s doing a lot of work, is very expensive to replace and a PITA to change. |
29th Jan 2020 8:05pm |
DerekV Member Since: 12 Oct 2015 Location: Surrey Posts: 39 |
Thanks everyone for your replies!!
X4SKP - Thanks. Just tried that and looks like I should be ok with most of the oils I've been looking at according to that. Bluest - Ah right, that's interesting, I'll look into that. Marks Landy - I'll look into that too. Anything that helps reduce transmission noise is certainly welcome!! So, it's looking like 75/80w90 EP is probably the way to go. Does anybody know for sure if GL5 is definitely ok throughout the transmission (except in the MT82). It's just that I've heard that it can cause increased wear of bronze/brass parts, compared to GL4, and I've heard that there's bronze in the T-box? Thanks! |
29th Jan 2020 8:10pm |
Landy Andy - I'll bear that in mind. I'm definitely going to go for a decent synthetic multi grade for the T-box whatever happens.
UtilityTruck - Thanks for the info. I'm thinking now then that I should get fully synthetic 75w90 for the transfer box, and fairly cheap Halfords/etc 80w90 for the diffs. |
29th Jan 2020 8:22pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 917 |
Hi andy.
Oil specs have got a bit muddled in the mists of time as specs improve but in essence it's the same old clunky units that was being wizzed about in 1950 If you haven't had it done then I would do the gearbox at the same time. it's a small capacity (2.2 ltrs) and no one has changed there's to find it in a nice condition the first time from the factory. Castrol Syntrans 75-90w multivehicle is a trusted replacement. For the T-box Then yes whilst it's still a basic unit Good oils will help keep the bearings and gears happy. I used Fuchs Titan Sintopoid 75 - 90 It is a synthetic oil it is a GL5 but reading the blurb it was claiming good things to help, The axles then yes any 75w - 90 will do but again something good will help keep the gears and bearings happy. I used Motul gear 300 as it's specs are good too. All brought from Opie oils as they are kinda local and easy to deal with Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
29th Jan 2020 10:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
I have Fuchs Sintopoid 75 - 90w in my Diffs. (GL5.)
The diffs may well be older tech, but for a few pounds I wouldn't run cheap oil in them. A new diff isn't the cheapest thing either. Unless of course, your running it into the ground to upgrade to something else. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jan 2020 12:23am |
Devon-Rover - Thanks for all the information. I'm leaning towards a synthetic 75w/90 in diffs and transfer now. And as for the gearbox, looks like I'll be doing that as well in that case!! Luckily it seems to be fairly clear-cut what oil to use in that!
custom90steve - Nope, point taken!! Not planning on selling it any time soon!! I think I'll put something decent in the lot then - probably synthetic 75w/90 as above. The only question that remains is whether there's any concern over using GL5 any more. I know that everyone here seems to be using it without issue, so it seems that it's not a problem, but I've read a few sites that say avoid it like the plague!! |
30th Jan 2020 8:18am |
I did exactly that called Opie... and at the time was recommended (and used) Motul Gear 300 for the Gearbox, Transfer Box, Front and Rear Differentials Specification 75W-90 / Racing gearbox and differential lubricant 100% Synthetic – Ester based STANDARDS API GL4 and GL5 / MIL-L-2105D Historical Pricing Click image to enlarge and issued midday today... Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
30th Jan 2020 9:17am |
Looks like the Gear 300 is a good bet - it says safe for use with yellow metals as well, so I needn't worry about the GL4/5 thing. I may have missed that discount now, but I've found it for £10.99/l here https://raceandrally.com/motul-gear-300-75...il-1-litre which works out a bit cheaper, so I'll probably order that from there.
Thanks everyone for your help and advice!! Derek. |
30th Jan 2020 2:28pm |
Click image to enlarge And for 'the record' the Land Rover / Castrol Recommended Lubricants and Fluids for the 2.4tdci Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
31st Jan 2020 11:17am |
Thanks X4SKP! That'll be useful for future reference.
Oil all ordered now. Went for the Motul Gear 300. |
1st Feb 2020 5:41pm |
