Home > Maintenance & Modifications > Transfer Box and Diff Oil
Page 2 of 2 <12
X4SKP
Post #813115 1st Feb 2020 7:17pm
BrickBox
Am I right in saying I need 9L of Motul gear 300 to do all diffs, gearbox and transfer case? 2008 2.4 110 Utility Station Wagon XS.
Post #971695 19th Nov 2022 4:01pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Gearbox has different oil. MTF I believe.. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #971724 19th Nov 2022 7:22pm
BrickBox
Reading back a page, I thought the gear 300 was for all the driveline? 2008 2.4 110 Utility Station Wagon XS.
Post #971725 19th Nov 2022 7:24pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
MT82 Gearbox requires oil that meets Ford WSD-M2C200-C specifications. At least this is what is stated in the workshop manual.
I use Castrol Transmax Manual Multivehicle 75W-90 (which replaces Castrol Syntrans Multivehicle 75W90), just because it says it meets this spec on the box.
It gives me peace of mind…
/Mat
Post #971771 20th Nov 2022 9:28am
MTF was used in earlier boxes but not in the MT82 in Puma engined vehicles. Darren
Post #971774 20th Nov 2022 9:40am
MK
Ford WSD-M2C200-C is PAO based. You can get away with non PAO based oil meeting 75w90 visc and GL-4 rating. Just need to change it more often. Puma 110" SW
Post #971790 20th Nov 2022 1:21pm
BrickBox
https://www.amazon.co.uk/Castrol-55761-Tra...&psc=1 2008 2.4 110 Utility Station Wagon XS.
Post #981486 6th Feb 2023 2:11pm
nitram17
just ordered this of Amazon......hope its not a knock off!
https://www.amazon.co.uk/Motul-105777-1001...mp;sr=8-10
Post #983173 21st Feb 2023 3:55am
stephan123
I plan on replacing the gearbox/axle oils as part of my upcoming Service B but not sure if the drain plugs must also be replaced as done when changing the engine oil....any advice would be much appreciated!
Post #1024183 10th Feb 2024 12:19pm
landy andy
You do not need to put purchase new drain or filler plugs. Unless you plan an upgrade in plug type. Thumbs Up
Post #1024191 10th Feb 2024 1:04pm
stephan123
Many thanks! Also, from what I've read, it seems that the filler plug level should be used for the transfer box and axles whereas the gearbox needs a specific amount of oil. Is this correct?
Post #1024230 10th Feb 2024 5:58pm
landy andy
Yes that is correct unless you have a proper Defender Wink Wink
All the information is here.
https://www.defender2.net/forum/topic8707.html
Post #1024231 10th Feb 2024 6:08pm
Page 2 of 2 <12
