Home > Tdi > FIP shaft and locking plates? |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 359 |
Yes, if I remember correctly it is a bit "Spring loaded".
Not sure why you removed the pipes. Just align everything and tighten the bolts.. I usually use a spanner on the big nut on the pump shaft to turn against the tension, to get the pin to move freely, before tightening the bolts. |
28th Jan 2020 5:37am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8085 |
what was the running issue or just changing the belt?
it would be unusual for the belt to have stretched to the extend the locking pin (or drill bit end) doesnt lock the FiP sprocket without undoing the 3 bolts. i usually lock that first anyway then see where the crank is. your talking sprung loaded without the belt on now i take it? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Jan 2020 11:40am |
KiwiNCFC Member Since: 14 Jul 2019 Location: East anglia Posts: 46 |
Thanks for your help guys. No I was just changing the pump timing to 1.54 from 1.4 as I've removed an egr. Ive watched loads of videos on how to do it but none of them mentioned that the pump had a 'springy' feeling to it so when I turned it i was worried incase I had majorly messed something up! All running fine now! I removed the fuel lines as I was using a dti gauge to measure pump lift. 👍🏻
28th Jan 2020 1:37pm |
glad you have it sorted Cheers
28th Jan 2020 2:56pm |
Cool. Glad you're sorted.
28th Jan 2020 3:14pm |
