Home > Tdi > FIP shaft and locking plates?
KiwiNCFC
United Kingdom 1997 Defender 90 300 Tdi HT Arles Blue
Any advice guys? I'm in the middle of checking the timing of the fuel injection pump on a 300tdi. The locking tool on the fuel pump wasn't going in squarely so I have undone the 3 bolts holding the locking plate on and removed 4 fuel lines from the pump and when I turn the 22mm shaft on the pump there is a lot of resistance and it almost feels 'springy' I have turned it a bit but it sort of then sprung and the nut is hard to turn again. Are they normally like this or have I got something else going on here? Thanks in advance!
Post #811908 25th Jan 2020 3:57pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Yes, if I remember correctly it is a bit "Spring loaded".
Not sure why you removed the pipes.
Just align everything and tighten the bolts.. I usually use a spanner on the big nut on the pump shaft to turn against the tension, to get the pin to move freely, before tightening the bolts.
Post #812273 28th Jan 2020 5:37am
jst
what was the running issue or just changing the belt?
it would be unusual for the belt to have stretched to the extend the locking pin (or drill bit end) doesnt lock the FiP sprocket without undoing the 3 bolts. i usually lock that first anyway then see where the crank is.
your talking sprung loaded without the belt on now i take it? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812304 28th Jan 2020 11:40am
KiwiNCFC
Thanks for your help guys. No I was just changing the pump timing to 1.54 from 1.4 as I've removed an egr. Ive watched loads of videos on how to do it but none of them mentioned that the pump had a 'springy' feeling to it so when I turned it i was worried incase I had majorly messed something up! All running fine now! I removed the fuel lines as I was using a dti gauge to measure pump lift. 👍🏻
Post #812316 28th Jan 2020 1:37pm
jst
glad you have it sorted Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812319 28th Jan 2020 2:56pm
jfh
Cool. Glad you're sorted.
Post #812320 28th Jan 2020 3:14pm
