![]() | Home > For Sale & Wanted > [Wanted] Damaged/Broken Crank Shaft for furniture |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
How damaged?
I have two that have been snapped in half... One is currently in an engine in the barn. The other has rusted up somewhat but should clean off easily. If you wanted I could probably weld the two halves together. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
It would be great to see a picture of the table when your done C01
![]() 2008 SVX 90 2000 XS TD5 90 |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Cheers Sako, that’s really kind of you. I’ve had a couple of PMs though and a few leads on complete units, and as I’m garbage at welding I need to go for a full one!!
Suli: I’ll post some pics when I’m done. I’ve had a really kind offer of three 300tdi cranks, so I’ll make a coupe of tables and stick one of them up in here for sale or blind auction or similar with proceeds being split between the site and help for heroes. |
![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
TobyMellin Member Since: 27 Dec 2017 Location: Manchester Posts: 16 ![]() ![]() ![]() |
I can supply you with ones of out trucks? 9-13 liter
Might struggle moving the table though ![]() |
Thanks Toby, but your right! Will be too heavy!
Looking forward to seeing the end result.
I have an old 13 litre hollow camshaft in the workshop that I've thought about making in to a lamp of some sort. suppose I'd best fix the 90 first ![]() |
![]() Click image to enlarge A mate just made me this “shed door handle’ for my birthday! |
Very smart indeed! A good friend!
Any news on this Co1, like to see some pics. 2015 HT XS 90
Still on the lookout Simon.
Still got two lying around here...
If after late Feb I might be able to glue them back together for you. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
In no rush for them Sako, so whenever suits you is great. I’ll be able to weld them as well, so don’t worry about glueing then back together!!
