Home > For Sale & Wanted > [Wanted] Damaged/Broken Crank Shaft for furniture |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
How damaged?
I have two that have been snapped in half... One is currently in an engine in the barn. The other has rusted up somewhat but should clean off easily. If you wanted I could probably weld the two halves together. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
15th Dec 2019 7:33pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
It would be great to see a picture of the table when your done C01 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
15th Dec 2019 8:29pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
Cheers Sako, that’s really kind of you. I’ve had a couple of PMs though and a few leads on complete units, and as I’m garbage at welding I need to go for a full one!!
Suli: I’ll post some pics when I’m done. I’ve had a really kind offer of three 300tdi cranks, so I’ll make a coupe of tables and stick one of them up in here for sale or blind auction or similar with proceeds being split between the site and help for heroes. |
15th Dec 2019 8:49pm |
worthy cause 2015 HT XS 90
15th Dec 2019 9:00pm |
TobyMellin Member Since: 27 Dec 2017 Location: Manchester Posts: 16 |
I can supply you with ones of out trucks? 9-13 liter
Might struggle moving the table though |
1st Jan 2020 4:52pm |
Thanks Toby, but your right! Will be too heavy!
1st Jan 2020 5:28pm |
Looking forward to seeing the end result.
I have an old 13 litre hollow camshaft in the workshop that I've thought about making in to a lamp of some sort. suppose I'd best fix the 90 first |
1st Jan 2020 5:32pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Click image to enlarge A mate just made me this “shed door handle’ for my birthday! |
1st Jan 2020 6:32pm |
Very smart indeed! A good friend!
2nd Jan 2020 6:12am |
Any news on this Co1, like to see some pics. 2015 HT XS 90
1st Feb 2020 9:05pm |
Still on the lookout Simon.
2nd Feb 2020 7:39am |
Still got two lying around here...
If after late Feb I might be able to glue them back together for you. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
2nd Feb 2020 9:21am |
In no rush for them Sako, so whenever suits you is great. I’ll be able to weld them as well, so don’t worry about glueing then back together!!
2nd Feb 2020 9:51am |
