Home > Puma (Tdci) > Maf sensor |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Ford Genuine is ideal, as your Defender like mine was a Ford motor and it IS acceptable in this instance to use Ford parts.
There is no compatibility issues with the LR system in this instance. If you use the 'Search' function in the bar above, you will likely find more info on this. I have even put up the P/N you are looking for. Trying searching 'MAF and MAP Sensors' you should be able to find it. LR are charging practically double the price if not even more for these parts.. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
1st Jan 2020 4:01pm |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 123 |
Thatโs great STEVE thank you , what do you clean them with ?
1st Jan 2020 4:16pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1780 |
I use an aerosol carb cleaner
Keith |
1st Jan 2020 5:26pm |
Cheers Kieth
1st Jan 2020 5:40pm |
I use Holts brake cleaner, both will work.
Blow though in the direction of airflow arrow on the top. And re-fit in the identical orientation of removal taking note of the airflow direction arrow. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
1st Jan 2020 6:26pm |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 60 |
I just ordered a new one off of eurocarparts they currently have a 50% sale with free delivery i think it cost about ยฃ45 for the new one
2nd Jan 2020 8:28pm |
