Home > Puma (Tdci) > Maf sensor
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Maf sensor
Is it worth trying to clean the maf sensor or should I just buy a new one and if so what company makes them for Landrover
Thanks bunny
Post #808377 1st Jan 2020 3:37pm
Ford Genuine is ideal, as your Defender like mine was a Ford motor and it IS acceptable in this instance to use Ford parts.
There is no compatibility issues with the LR system in this instance.
If you use the 'Search' function in the bar above, you will likely find more info on this.
I have even put up the P/N you are looking for.
Trying searching 'MAF and MAP Sensors' you should be able to find it.
LR are charging practically double the price if not even more for these parts.. Chillin In The Backwoods🇬🇧🇺🇸
Post #808383 1st Jan 2020 4:01pm
bunnyman
That’s great STEVE thank you , what do you clean them with ?
Post #808387 1st Jan 2020 4:16pm
ickle
I use an aerosol carb cleaner
Keith
Post #808392 1st Jan 2020 5:26pm
bunnyman
Cheers Kieth
Post #808397 1st Jan 2020 5:40pm
I use Holts brake cleaner, both will work.
Blow though in the direction of airflow arrow on the top.
And re-fit in the identical orientation of removal taking note of the airflow direction arrow. Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #808406 1st Jan 2020 6:26pm
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
I just ordered a new one off of eurocarparts they currently have a 50% sale with free delivery i think it cost about £45 for the new one
Post #808537 2nd Jan 2020 8:28pm
