Home > Maintenance & Modifications > 2007 Mantec Snorkel |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
12th Nov 2007 9:37pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
You will need to drill 2 holes just above the air intake grille Andy
1st Dec 2007 8:38pm |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 270 |
Thanks Andy, do you think drilling holes in the metalwork devalues the vehicle JE Zulu 110 now sold
Carpathian 110 also sold Defender 110 camper now in build |
1st Dec 2007 9:19pm |
Maybe but when I sold my D3 I removed the snorkel and filled and painted over the holes. You couldn't tell anything had been there. Andy
1st Dec 2007 10:15pm |
Thanks JE Zulu 110 now sold
1st Dec 2007 11:16pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
When there's just a couple of holes left after removing a piece of kit I find it better to simply plug them with stainless steel, cup-head screws rather than try to cover them completely. Let's face it, it's a Defender with exposed rivets and everything so a couple of extra shiny screws won't make a difference. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
2nd Dec 2007 1:06am |
Good idea, maybe I would even paint the screws keswick green JE Zulu 110 now sold
3rd Dec 2007 4:09pm |
Just got my Mantec kit today, the instructions are useless
Most if it is fairly obvious but not sure about how to fix the mounting bracket to the windscreen pillar, the kit includes 10mm bolts which it claims are self-tapping, not sure though as they have blunt ends rather then pointed, guess it's a case of drill the hole and hope for the best Andy |
3rd Dec 2007 4:28pm |
I hate drilling painted surfaces you only get one chance JE Zulu 110 now sold
3rd Dec 2007 4:49pm |
The bolts/screws do seft-tap in OK, just make sure you drill the correct size holes |
4th Dec 2007 12:59pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
So are these a DIY job or do I need some special tool for the captive nuts that go in the wing above the vent?
17th Feb 2008 11:36am |
You need a rivnut expander tool Andy
17th Feb 2008 11:44am |
I will bring my rive nut tool to Yarwell we can fit them then. You drill the holes before you leave. |
17th Feb 2008 1:37pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 |
Fitted Mantec plastic Snorkel yesterday.
Handy fit - Thanks Andrew for details photos. I didn't have a Rivenut gun - But bolted it thru the wing instead. If you remove the plastic cover on top of the wing its easy enough get some lock nuts on. Its a good job that new snorkle, no vibration and does not obstruct your view thru windscreen as some others do. |
17th Feb 2008 4:43pm |
