Home > Maintenance & Modifications > 2007 Mantec Snorkel
Page 2 of 3 <123>
AndrewS
CFB wrote:
Sounds like the same method as the D3 install, 2 x captive nut brass thingies above the wing duct?
Thumbs Up
Post #673 12th Nov 2007 9:37pm
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
Andrew, When you fitted the mantec RAI, I realised you had to drill the A pillar, but did you have to drill the wing too Question JE Zulu 110 now sold
Carpathian 110 also sold
Defender 110 camper now in build
Post #803 1st Dec 2007 7:27pm
CFB
You will need to drill 2 holes just above the air intake grille Andy
Post #804 1st Dec 2007 8:38pm
Michaels Defender
Thanks Andy, do you think drilling holes in the metalwork devalues the vehicle Question JE Zulu 110 now sold
Post #805 1st Dec 2007 9:19pm
CFB
Maybe but when I sold my D3 I removed the snorkel and filled and painted over the holes. You couldn't tell anything had been there. Andy
Post #806 1st Dec 2007 10:15pm
Michaels Defender
Thumbs Up Thanks JE Zulu 110 now sold
Post #807 1st Dec 2007 11:16pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
When there's just a couple of holes left after removing a piece of kit I find it better to simply plug them with stainless steel, cup-head screws rather than try to cover them completely. Let's face it, it's a Defender with exposed rivets and everything so a couple of extra shiny screws won't make a difference. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #808 2nd Dec 2007 1:06am
Michaels Defender
Good idea, maybe I would even paint the screws keswick green Thumbs Up JE Zulu 110 now sold
Post #816 3rd Dec 2007 4:09pm
CFB
Just got my Mantec kit today, the instructions are useless Sad
Most if it is fairly obvious but not sure about how to fix the mounting bracket to the windscreen pillar, the kit includes 10mm bolts which it claims are self-tapping, not sure though as they have blunt ends rather then pointed, guess it's a case of drill the hole and hope for the best Shocked Andy
Post #818 3rd Dec 2007 4:28pm
Michaels Defender
I hate drilling painted surfaces Crying or Very sad you only get one chance JE Zulu 110 now sold
Post #820 3rd Dec 2007 4:49pm
AndrewS
The bolts/screws do seft-tap in OK, just make sure you drill the correct size holes Thumbs Up
Post #822 4th Dec 2007 12:59pm
JSG
So are these a DIY job or do I need some special tool for the captive nuts that go in the wing above the vent?
Post #1405 17th Feb 2008 11:36am
CFB
You need a rivnut expander tool Andy
Post #1406 17th Feb 2008 11:44am
AndrewS
I will bring my rive nut tool to Yarwell we can fit them then. You drill the holes before you leave. Thumbs Up
Post #1407 17th Feb 2008 1:37pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Fitted Mantec plastic Snorkel yesterday.
Handy fit - Thanks Andrew for details photos. Thumbs Up
I didn't have a Rivenut gun - But bolted it thru the wing instead. If you remove the plastic cover on top of the wing its easy enough get some lock nuts on.
Its a good job that new snorkle, no vibration and does not obstruct your view thru windscreen as some others do.
Post #1409 17th Feb 2008 4:43pm
Page 2 of 3 <123>
