Home > Maintenance & Modifications > BAS 150BHP map |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Have an SV Roadsport with Duratec conversion from Raceline. R420 Spec. Love the Defender for what it is, but the Caterham puts a bigger smile on my face! |
5th Dec 2019 11:38am |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Good to know there is another Caterham 620 owner on here!
I still think a Defender and a Caterham is the perfect two car garage. Although my Defender is a lowly old TD5! Click image to enlarge |
22nd Dec 2019 11:39am |
notxal Member Since: 20 Nov 2019 Location: Shropshire Posts: 89 |
Hi Nigel, we seem to be like minded. My Puma 90 is a recent acquisition and I'm loving it. Its become my daily for the winter months now I'm retired.
22nd Dec 2019 1:34pm |
Great looking 90 bud!
And wow, how clean is it? Mine has never been that clean, but it does spend almost all of its life off road. Click image to enlarge |
26th Dec 2019 8:46am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
mine's had the BAS map for 9 years now, engine running like it was still new -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
27th Dec 2019 7:22am |
Drmatt Member Since: 06 Jun 2020 Location: Norfolk Posts: 3 |
So I’m a bit late to the party. I’m planning to get a remap from Pete at BAS who has been incredibly helpful.
Before I push the button any more experiences (good or bad) I should bear in mind? Cheers |
9th Oct 2020 10:55pm |
Just do it, and then you'll wonder why you didn't sooner!
Highly recommend that you fit an Engine Monitoring System to drive according to the EGTs though -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
10th Oct 2020 5:32am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Ditto, well worth it, totally transforms driveability. James
10th Oct 2020 6:31am |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
BAS 170 here and it's the best mod I've done (2014 2.2 110) by miles. Just remember you do have to push the throttle pedal down to get the umph though. I was a bit underwhelmed for a start, until I realised that!
If you don't use yours off road, an Alive Tuning Eibach rear anti-roll bar will ensure the increased power doesn't leave you in the ditch (my second best mod) too. I wouldn't mess about with the 150 though. You might as well have the full works. |
10th Oct 2020 6:43am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3686 |
I concur with Joe. I had the 150 first and it was great but then Pete upped it to 170 while I was there for something else. Big difference and unless you tow there is no need for a bigger intercooler. Best mod on the vehicle.
10th Oct 2020 7:15am |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
jumping on the bandwagon here, the BAS tunes are fantastic. keep in mind if you buy the 170 on the RRC tool, you get the 150 as well. The 150 tune is remarkably smooth, its a real beauty. the 170 is virtually the same, but there is more torque, and after about 80% throttle it just goes like stink.
Ive run the 170 since June on the stock intercooler including driving from CH to NO in august and spending a month there touring. only problem encountered was a stock intercooler hose ruptured, but that would have happened regarless of tune or not. Like you, i was on the fence for a while. but after the tune I felt a bit like i had wasted some good years of my life by not buying it sooner! Roaming around 🇳🇴🇨🇭 |
10th Oct 2020 7:33am |
Thanks all! I’ve been talking to Pete about the 170 but had hesitated to push the button....
Thanks for the advice- sounds like it’s the way to go and good to hear it’s been ok on stock intercooler. |
10th Oct 2020 10:41am |
it's good on a standard IC, but you might as well get the BAS one to take full advantage of the remap --
10th Oct 2020 10:49am |
I've got the BAS intercooler and all his hoses, but they made no difference to the performance (which was what I expected).
However, Pete does his uprated turbo too, and you need them for that. I still can't quite justify the cost as it's so good with the tune as it is, but as everything is ready for it, it's so tempting. |
10th Oct 2020 11:12am |
