Home > Technical > Washer jet nozzle maintenance.
spudfan
Ireland
Right this has been posted in the "Technical" section as it is rather technical.
Christmas is almost upon us and thus there will be lots of gifts flying about. Some of these will been securely held in place in a box by lengths of plastic ties with a thin metal strip in the middle. These can be very useful so keep some.
If you pare back the plastic with a knife, you might want to get an older responsible person to use the knife, you can expose the metal strip. This is ideal for poking into the washer jets to unblock them. You can expose enough of the wire to go right down in to the nozzle. I always carry a piece with me for this purpose.
I was going to call this thread "How to do some exposing and poking"...…. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #806611 17th Dec 2019 1:52pm
Litch
Personally I just use a pin.
My old dad told me when I bought my first car to stick a pin into the edge of the sun-visor so it is always available to unblock / adjust the washer nozzles.
Always done it and it has never let me down. ONE LIFE, GET IT!
Post #806649 17th Dec 2019 6:50pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I did the same before I got this fan spray nozzle http://www.csiparts.co.uk/en-gb/collection...jet/165077
Post #806654 17th Dec 2019 7:13pm
htb2
Wales
£80 squid, too much for me. Laughing
Post #806659 17th Dec 2019 7:51pm
OK, in the washer jet theme....
My Td5, has the weakest front washer pump going.... it's crap.
Anyone suggest a replacement pump that can be made to fit the washer bottle easily-ish (without spending the small fortune for that nice aluminium adaptor to fit the disco Td5 pump)
I'm not bothered about fitting anothe vehicles' make of pump and bonding it into place with tiger seal.... that should do the trick!
Would just like some better pressure and flow. I've already fitted 2x standard twin jets to the front screen, just need more water there. (don't want pipes up the wiper arms either)
Post #806675 17th Dec 2019 9:23pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Swap over to the rear pump? It is more powerful anyway.
It is as easy as swapping over the electrical connections and the pipes.
Post #806847 19th Dec 2019 9:32am
kallito
Italy 2009 Defender 110 Puma 2.4 SW Alaska White
You could consider trying a headlight/windscreen washer pump for a Discovery3 or Range Rover.
quick search revealed part number DMC500020 instead of original DMC100540/DMC100550
I guess it'll fit into the seal and use same type of connectors
from the pictures it seems to have the same connections
as a general rule headlight washer pumps - especially when they only spray and don't have wipers helping out -
need a lot of spraying power in order to clean the headlights.
according to fuse box diagram
Discovery 3 -> headlight/windscreen washer 25A
Defender Puma -> rear wipers/wash 10A "Don't drink and drive. You might spill your drink."
Post #806853 19th Dec 2019 10:25am
Roy5695
Thats a lovely picture Whistle Embarassed this was before i fitted the disco 3 headlight washer pump too. absolutelt incredible with a 10mm internal diameter feed pipe and the new pump! *** new pump needs to be fed from a rel,ay though as the power required to make it pump is around the 17Amp mark!! works extremely well though! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #806865 19th Dec 2019 12:35pm
Have you fitted a water butt in the back to deal with the supply issues Wink
Post #806879 19th Dec 2019 2:54pm
I've just done a little digging, the LR pump DMC100550 is a Durite 0-594-61
I think the problem I had/have with my current pump is it came in either a blue or white (bearmach) box... IIRC either way it didn't exactly astonish me when I first fitted it... .so might try the durite one.
Good idea Kallilto... might try something like that also....
Post #806920 19th Dec 2019 6:38pm
You won’t go far wrong with Durite. Always had very good quality from them. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #806926 19th Dec 2019 7:08pm
I use a Disco 2 headlight washer pump for the screen, and (IIRC) a Rover Metro headlight washer pump for the headlight jets. The pumps are actually the same alert from the angle of the outlet, the Rover pump being necessary to allow the delivery pipe to clear the second pump.
Both are incomparably better than the original.
Post #806927 19th Dec 2019 7:12pm
^^^ Was the D2 headlight pump a direct fit to the defender water reservoir? or need that fancy adaptor?
Post #806928 19th Dec 2019 7:27pm
Roy5695
I didn’t need an adaptor for mine. Just pushed the pump into the original hole. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #806965 19th Dec 2019 10:40pm
doublecabjon
Check the bottle isn’t full of black solidified screen wash jelly stuff. That can cause a supply problem.
That csi washer nozzle does look lovely though...
Post #808769 4th Jan 2020 10:48pm
