Home > Off Topic > Rats and Mice
Page 1 of 3 123>
discomog
Rats and Mice
Knowing that members of Def2 have a wealth of knowledge on most if not all subjects, here is a question for you. Do you have any experience of using ultrasonic rodent deterrents? My barn seems to be a haven for them at the moment and I'm continually setting traps. The problem is that the clean kill rate is only about 50 per cent and I seem to be forever having to despatch them on a morning when I open up. I don't have a problem despatching them but hate to think that they have been injured in the trap all night, hence the question about the effectiveness of ultrasonic deterrents. I much prefer to have them not come into the barn in the first place. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #805216 7th Dec 2019 5:59pm
grafty99
We have ultrasonic deterrents in the garage portion of our workshop. They just plug into a standard socket. Fit and forget.
We have had mice in the store room but not in the portion with the ultrasonic deterrents. (we have traps in there as there isn't power)
I'd recommend them but I'm not sure how large an area they're effective for. The garage portion of our workshop is probably a generous double garage size and there are 2 plugged in there Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #805218 7th Dec 2019 6:03pm
Sulisuli
We have 3 plugged into our “barn” and we live in it Rolling with laughter but it’s certainly stopped the mice coming in to join us on winters evening, much nicer than traps. We have found them to very effective and would recommend them 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #805220 7th Dec 2019 6:10pm
Tim in Scotland
I have an ultrasonic deterent device in my single garage that is integral to the house , it’s been plugged in for over 10 years and since plugging it in I’ve not had any mice come back (they stripped the sound insulation matting from the underside of a Volvo 480 bonnet and had a go at the wiring loom one winter). I also used to hear them in my loft at night but since fitting an ultrasonic thing in my hall (it’s a bungalow) I have never heard scurrying paws up in the roof space in the night. We had field and harvest mice as I live on the edge of open fields. I don’t mind them in the garden but not in the house and I often see them munching sunflower heads that have been cut off for wild bird feeding at this time of year. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #805222 7th Dec 2019 6:12pm
discomog
Thanks for your rapid responses. Thumbs Up I'll purchase two for the barn and one for the adjacent feed room and then put my traps into storage in case of a prolonged power cut. Defender 90XS SW
Morgan Plus 8
Post #805226 7th Dec 2019 6:17pm
dorsetsmith
most mice must be deaf around here as the only thing that work is peanut butter and traps or good raters and 22
Post #805229 7th Dec 2019 6:30pm
chalky
I’ve had a few in the garage before and they did nothing ! Resorted to live traps with tootsie roll on with peanut butter on !
I’ve also used an old galvanised mop bucket with grain in the bottom which resulted in double figures, I’m dreading them getting into my wiring loom and chewing thro wires. DEFENDER XS CSW 08 TONGA GREEN
Post #805230 7th Dec 2019 6:35pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
We have had no luck with the ultrasonic. Traps and poison is the only thing that works for us.
Post #805232 7th Dec 2019 6:45pm
donmacn
Very topical for me at the moment. I discovered that the foam of a bellhousing cover had been trashed and turned into diced foam; they've also been at the dried "aerosol" foam which seals the gaps between the corrugated walls and the floor.
...and I'm with Dorset Smith I'm afraid, there have been two ultrasonic things plugged in for years, and they don't seem to have been a deterrent at all.
Put out some more traps - 4 in total now in what is a reasonable double garage, and some poison block feeders I got in BnQ. Got two in the traps, and they've taken a bit of the poison, but there's still evidence of activity.
Is there any way of testing whether the ultrasonic things are making any sound at all, given that we can't hear them? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #805233 7th Dec 2019 6:48pm
jst
We tried ultrasonic devices, didn't work for us. Suprised you dont get instant kills with mice traps. Is that rats in mice traps not dying or mice not dying? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805242 7th Dec 2019 7:37pm
chalky
If you have access to a decibel reader you should be able to see a small gain in audible noise on the dial ?
As you say we can’t hear it but the noise is there !!!! I plugged them in my garage but left the traps ! I swear they took the noise as some kind of access code to a family party invite !
There are some ingenious mouse catching methods on you tube and on line, they should be hibernating by now and my traps havent seen action for a week or more ! DEFENDER XS CSW 08 TONGA GREEN
Post #805243 7th Dec 2019 7:38pm
Tim in Scotland
The poison blocks from B&Q are also quite good if you can put them where they are finding a gap to get through - they are called something like Big Cheese mouse poison - a block of food they have to go passed in a plastic mounded holder that is refillable. Thing is they have to munch a fair bit of it before finding a corner to curl up and die in with those but they are effective and you don’t find dead mice lying around with them either. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #805247 7th Dec 2019 8:05pm
Just be careful where you get it from.
Post #805342 8th Dec 2019 3:21pm
Slideywindows
Poison. Works for me and I don't have to put any more down from Christmas until next autumn.
Are we certain that non-target creatures are unaffected by those noise machines?
Post #805355 8th Dec 2019 5:20pm
grafty99
The ultrasonic deterrents certainly don't seem to bother my dogs, or the house Martins that nest in the eaves each year Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #805357 8th Dec 2019 5:41pm
Page 1 of 3 123>
