![]() | Home > Maintenance & Modifications > Removing steering wheel |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17628 ![]() ![]() ![]() |
If it is that firmly stuck on the taper, your only choices really are to remove the column cowl behind the wheel to provide enough back-clearance to fabricate a puller, or to destroy the wheel by cutting it.
![]() Before doing this, I would suggest checking the misaligment of the wheel by centring the steering box first, if you haven't already done so. Some boxes are drilled for a centring bolt which passes through notch in the back of the drop arm into the bottom face of the box, which provide a positive centre. Later boxes don't have this (value engineering again!) but you can still centre the box by counting the turns lock-to-lock and noting the steering wheel positions at either lock (with the drag link disconnected so the lock-stops don't limit travel), and then figuring out the number of turns and wheel position from either extreme to the mid-point. It may be that the steering wheel is straight but the drag link needs adjusting. I have never understood what kind of halfwit tightens steering wheel nuts that tight; doing so just indicates a profound lack of any kind of mechanical understanding or common sense and suggests that the person doing it shouldn't be allowed near tools! |
Yulong Member Since: 18 Nov 2017 Location: Aberdeen Posts: 110 ![]() ![]() |
Very careful application with a heat gun?
To update this thread... I had issues remove my steering wheel recently. Didn't have a big enough puller, no tapped holes to use etc etc.
Tried thwacking it with a rubber mallet and a dead blow, nothing. Wiggling didn't have any effect, nor penetrating oil. What did work incredibly well was an air hammer on the back. One quick burst of the trigger and the wheel was off before I'd even blinked. |
Plump Donkey Member Since: 02 Sep 2022 Location: Surrey Posts: 3 ![]() ![]() ![]() |
Had this issue myself the other month when I was removing the dash. Unfortunately the wheel had no holes for the tool so tried some heavy longitudinal, Lateral and radial agitation, As much heat as I dare before the wheel melted off, Lots if swearing and sweating that didn't work either, I even tried being nice to it and promising it some new window blocks.
In the end I resorted to drilling a couple of holes and tapping them so I could knock up a puller and it finally came off! Found a new way to bend 1/2in steel in the process too ![]() |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
This is how I did mine when it wouldn't budge.
![]() ![]() Click image to enlarge |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I like that ^
![]() Did you leave the ratchet strap on under tension whilst ‘helping’ it release with other activities? When I did mine a fair few years back the simple hub puller worked (thankfully). |
Yeah that's it. Was under alot of tension! Then whacked the back of it with a softblow hammer a couple of times and it popped off.
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 192 ![]() ![]() ![]() |
Luckily I have the old style wheel, made my own puller using the two holes.
Before this tried using hammers and strops, would not come off. Even now been off a few times, still needs the puller. |
