Home > Maintenance & Modifications > Split Charge VSRs and Battery Types |
I think this is a myth. Split charging has been used in the caravan world for decades without issue and the batteries are never the same as the tow car. Darren
25th Apr 2019 8:30pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
I agree with Anorak, my batteries are completely different and i've never had an issue with either.
I think a decent VSr is more important with the correct wiring and breaker in line between the 2 batteries. |
25th Apr 2019 9:25pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
That's good, some reassurance all will be well with my set up once it is in. 2007 110 TDCi Station Wagon XS
26th Apr 2019 11:35am |
rsms Member Since: 12 Jan 2013 Location: Home Posts: 36 |
There is a very good post on subject by achuakh
https://www.defender2.net/forum/topic63989.html RSMS |
21st Oct 2019 2:52pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8022 |
If you connect batteries perm in parallel they need to be identical size/ah. If connected via a vsr so they are disconnected when alt is not charging it doesn't matter on size discrepancies. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Oct 2019 4:07pm |
