Home > Maintenance & Modifications > Split Charge VSRs and Battery Types
Bluest
I’ve read a lot on the internet about nearly every aspect of split charge systems, but I’m still not clear on one thing. There are many comments saying VSRs are great as long as both batteries are the same, but it is never clear what people mean by the same. And that if they aren’t “the same”, it can destroy the aux battery in short order.
Is that true and what does “the same” mean? Identical in every regard? Same capacity? Same chemistry?...
At the moment, my starter battery is a Varta LDF90 flooded lead acid dual purpose 90ah. The leisure battery I have to go in is a 120ah AGM dual purpose battery. If I hooked that up through a VSR will I have am effective and reliable system? 2007 110 TDCi Station Wagon XS
Post #770059 25th Apr 2019 6:03pm
I think this is a myth. Split charging has been used in the caravan world for decades without issue and the batteries are never the same as the tow car. Darren
Post #770116 25th Apr 2019 8:30pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I agree with Anorak, my batteries are completely different and i've never had an issue with either.
I think a decent VSr is more important with the correct wiring and breaker in line between the 2 batteries.
Post #770132 25th Apr 2019 9:25pm
Bluest
That's good, some reassurance all will be well with my set up once it is in. Thumbs Up 2007 110 TDCi Station Wagon XS
Post #770192 26th Apr 2019 11:35am
rsms
Slovenia
There is a very good post on subject by achuakh
https://www.defender2.net/forum/topic63989.html
RSMS
Post #798940 21st Oct 2019 2:52pm
jst
If you connect batteries perm in parallel they need to be identical size/ah. If connected via a vsr so they are disconnected when alt is not charging it doesn't matter on size discrepancies. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #798946 21st Oct 2019 4:07pm
