![]() | Home > Maintenance & Modifications > Split Charge VSRs and Battery Types |
I think this is a myth. Split charging has been used in the caravan world for decades without issue and the batteries are never the same as the tow car. Darren
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I agree with Anorak, my batteries are completely different and i've never had an issue with either.
I think a decent VSr is more important with the correct wiring and breaker in line between the 2 batteries. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
That's good, some reassurance all will be well with my set up once it is in.
rsms Member Since: 12 Jan 2013 Location: Home Posts: 36 ![]() ![]() |
There is a very good post on subject by achuakh
https://www.defender2.net/forum/topic63989.html RSMS |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8219 ![]() ![]() ![]() |
If you connect batteries perm in parallel they need to be identical size/ah. If connected via a vsr so they are disconnected when alt is not charging it doesn't matter on size discrepancies. Cheers
