Home > Maintenance & Modifications > Which Spare Wheel Carrier?
Page 4 of 5 <12345>
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
Mantec Spare Wheel Carrier
Well Gents, fitted the above carrier to my new 90 five years ago, and guess what! The dreaded ferrous oxide has started. The NAS step was horrendous so that has been removed, galvanised and powder coated and refitted. Now the attention is on the carrier. Suggestions would be appreciated. Should I remove strip, galvanised and re coat, replace like for like or go for a more expensive single attachment carrier?
Constructive suggestions welcome!
Cheers WYL
 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #798815 19th Oct 2019 11:53pm
Swine&Small
Bite the bullet...Nakatanenga Stainless...money saved in the long run. Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #798833 20th Oct 2019 12:09pm
Both are valid options. Given that you've already drilled holes for it, I'd be inclined to refurb what you already have. Darren
Post #798838 20th Oct 2019 12:44pm
Rear Wheel Carrier
Gents do you know if the Nakatanenga will fit with the NAS step?
I know I had problems removing the step as I’ve got an additional fuel cell fitted that restricts access to the rear crossmember.
Perhaps a refurb of the original may be the best option as the holes are already in the capping!
Cheers WYL 2015 90 Keeper
2005 R300 Keeper
Post #798847 20th Oct 2019 5:24pm
Swine&Small
Sorry, I cannot help with that , although I have the Naka carrier I do not have the step.
Good point though. 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #798849 20th Oct 2019 5:32pm
Zed
Re: Rear Wheel Carrier
Cheers WYL
Yep, Nakatanenga fits fine with a NAS step.
Post #798850 20th Oct 2019 5:41pm
Si
Cheers WYL
NAS &amp; NAK by sma.ll, on Flickr
Post #798851 20th Oct 2019 5:44pm
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
I've got what was a Scorpion Racing rear carrier for those with good memories. I took it off last year after it was on for probably 10 years and was disappointed to see pretty much all the power coating flaking off. I've had it soda blasted and recoated and I am really happy with how it has come up and over the expense of £300+ on a new one.
Mine was quite badly flaking, especially on the mounting brackets that fit to the body work so you can see they are pitted through the fresh coating but overall I am really glad I did it. I think it cost about £120 all in for blasting and coating. I might have a picture I can attach if needed. 1984 90 V8 puma want to be.
Post #799145 23rd Oct 2019 11:51am
Ge03rad
Hello all. New member and recently picked up a 2009 Defender 90. Well chuffed but seems every time I look at it I end up wanting to buy something else!
Anyway, I bought a Mantec spare wheel carrier last week and got round to fitting it yesterday. I inadvertently bought the older ‘original’ one that doesn’t come with nut plates for the rear so fitting was a nightmare to say the least! Have just used washers for now but think it may be sensible to try get some spreader plates made up too.
After fitting I tried to get my spare boost alloy on and there’s not enough clearance between the wall of the tyre and the carrier arm? Has anyone come across this problem before and what did you do? From a bit of research I found that defender upgrades sell Dedendee mantec spare wheel Extension studs (in photo) but these are £48 with delivery etc?! Surely a cheaper option available?
Any help much appreciated!
Post #823467 5th Apr 2020 12:49pm
That issue has come up before and the only solution really is to fit stud extenders. I can't help on the price though, and whether that make is the only option. Darren
Post #823468 5th Apr 2020 1:02pm
I'd like one that did this.
Post #824137 8th Apr 2020 5:36pm
Ingenious but cumbersome. I can see the benefit if running 40 inch tyres, though. Darren
Post #824180 8th Apr 2020 9:22pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Does the tyre not fit with the alloy inverted ? Probably not the look you want but if you’re putting a cover over it then it wouldn’t matter https://www.instagram.com/hustynminepark/
Post #824247 9th Apr 2020 12:19pm
An alternative to stud extenders would be to use a wheel spacer. The only problem is finding someone who will supply a single one rather than a set of four.
Post #824249 9th Apr 2020 12:22pm
miker
leeds wrote:
Whilst I have not seen the actual regulations regarding the legality of 2 stage opening wheel carriers and passengers in the rear of vehicles, the person who informed me is normally very clued up on vehicle law.
The law can change between countries about vehicle construction etc. However anything which prevents easy access from a vehicle can increase the danger in the event of an incident.
Apart from police paddy wagons and security wagons how does the use of child vehicle locks also impact on safety in the event of an incident? A case of balance of probabilities??
Brendan
I was also under the impression that you had to be able to open doors from the inside if there were seats! However the gov MOT page, (not C&U I know but still) says otherwise:
2.8 Doors
These will be inspected to check that:
the latch is secure in the closed position
the front doors open from inside and outside the vehicle
the rear doors open from outside the vehicle
hinges and catches are secure and in a good condition
https://www.gov.uk/government/publications...-at-an-mot
Post #824267 9th Apr 2020 1:42pm
Page 4 of 5 <12345>
